Old October 26th, 2009, 06:03 PM   #1 (permalink)
action trouble
when i purchased my tele, it had 9's and i updated to 10's. the action is way higher now. it's not terrible but i am wondering the simplest way to lower it. thanks
J-Tub
jacoblcarroll is offline   Reply With Quote
Old October 26th, 2009, 06:50 PM   #2 (permalink)
schoolie's Avatar
How is the neck relief? Put a capo on the 1st fret and press down on the 20th fret. How high are the low E and high E strings above the 7th fret? Should be 0.006-0.008". Feeler gauges from an auto parts store are very handy for this:)
You night just need a clockwise tweak of the truss rod, to straighten out the neck a bit. I would be surprised that going from 9 gauge to 10 gauge strings would make a huge difference in the neck relief. Was it high before?
schoolie is offline   Reply With Quote
Old October 27th, 2009, 12:39 AM   #3 (permalink)
with the factory strings the action was real low. it was nice. i just put on 10 gauge boomers and now it plays almost like an acoustic. i don't know the deal
J-Tub
Old October 27th, 2009, 02:00 AM   #4 (permalink)
patrickhowell's Avatar
Heavier gauge strings pull harder on the neck. You have to tighten to truss rod to counteract that. Turn it 1/4 turn clockwise and then play it for a few days. If it is still to high, give it another 1/4 turn. It takes time for the neck to adjust to the new strings and truss rod tension, so don't over do it.
patrickhowell is offline   Reply With Quote
Low action Buzz, or High Action No buzz? JohnnyRebKy Telecaster Discussion Forum 6 January 10th, 2009 10:29 AM
trouble with action on newly assembled partcaster thickfreakness Tele-Tech 10 October 28th, 2008 09:42 AM
trouble adjusting intonation & action phillyd Tele-Tech 12 January 24th, 2008 06:19 PM
ok, i'm in trouble flatheadtele Telecaster Discussion Forum 7 March 14th, 2007 01:42 AM
What is Good String Action, when someones says, good action! dallendo Tele-Tech 12 August 24th, 2004 10:09 PM
