Old October 26th, 2009, 04:51 PM   #1 (permalink)
casey2910's Avatar
cheap pots
i posted this question in the main forum, but now think that was the wrong thing to do, im kindof( ok a lot ) dumb with the forum/computer user thing. my apoligies.
Question: i just received a douglas wf 150 as a gift. the volume pot is really wiggly and the tone pot not much better. i havent had time to open up the control plate and was wondering which type of pots i should buy to replace them. i wanted to pick them up before i traveled back home tonite. its a 65 mile commute! just average for most of use but i wanted to start soon. guess i may end up going home empty handed and just opening up the plate and check the values of the sorry pots in question and then go from there. thanks for the eyes since you dont need ears to listen to this rambling note.
by the way, was needing suggestions for replacements. i think i want to stick with a no load tone pot simular to my amer. stand. tele.
a tele is a swiss army knife and a scalpel all in one. it is a precision instrument and it can cover any music to boot.
casey2910 is offline   Reply With Quote
Old October 26th, 2009, 06:04 PM   #2 (permalink)
garymaddox's Avatar
Get good pots. The cheaper ones aren't that much cheaper than a quality CTS.
garymaddox is offline   Reply With Quote
Old October 26th, 2009, 07:05 PM   #3 (permalink)
KevinB's Avatar
Get CTS (or Fender branded CTS) solid shaft pots. It just doesn't make sense to buy $3 cheapies when the truly excellent ones can be had for $6.
Be aware though that your control plate may be hole punched for a metric size, and might need a little reaming to accept the USA-spec CTS shafts. It's easy to do though and is covered by the nut and the knob anyway.
Old October 27th, 2009, 10:28 AM   #4 (permalink)
casey2910's Avatar
thanks guys!
should i change from the factory 500k to what i see as the fender 250k standard?
Old October 27th, 2009, 12:16 PM   #5 (permalink)
indiobravo's Avatar
Originally Posted by casey2910 View Post
thanks guys!
depends on what you will do with the pickups. there are some basic standards that most stick to. 250 for single coil (standard tele-type pups), and 500 for humbuckers and P-90 types. so if you plan to replace them - then i would get pots in anticipation of the new pickups. otherwise, as long as you like the basic brightness of the ones you have in there - i would replace with like-valued pots.
whatever floats your boat. :-)
indiobravo is online now   Reply With Quote
Cheap Guitars with Cheap Amps and Cheap Pedals...Can 2+2+2 = 15? studio1087 Bad Dog Cafe 35 July 12th, 2009 11:10 PM
Cheap date/cheap entertainment in your area? sean79 Bad Dog Cafe 11 September 6th, 2008 09:34 AM
Linear Pots vs. Audio Pots (Les Paul question) Pesty Tele-Tech 10 January 9th, 2008 09:52 AM
Converting 500K pots to 250K pots Donovan_45 Tele-Tech 7 September 18th, 2006 03:08 PM
Cheap DIY P-90 guitar project: Cheap P-90 pickups? 6942 Just Pickups 10 July 4th, 2006 02:33 PM
