Old October 26th, 2009, 02:16 AM   #1 (permalink)
22 fret neck for MIM Nashville deluxe tele
Hi,
Who makes a bolt on 22 fret neck that will fit a MIM Nashville Deluxe Tele? I have looked online and i can't seem to find an "off the shelf" neck.
Thanks,
Kent
Kwall is offline   Reply With Quote
Old October 28th, 2009, 10:53 AM   #2 (permalink)
22 fret Tele necks non-existent?
Originally Posted by Kwall View Post
Hi,
Thanks,
Kent
Owie....guess there's nothing out there? If you guys don't know then nobody does! :-(. I had even contacted one of the premier aftermarket neck/body companies and they wouldn't/couldn/t give me a clear answer...
BUT...if anyone has installed a 22 fret neck on a MIM Nashville Deluxe Telecaster I sure would like to hear from you.
Thanks!
Kwall
Old October 28th, 2009, 11:05 AM   #3 (permalink)
varakeef's Avatar
I think any neck maker on should be able make you such a neck. Or is there something in Nashville Deluxe Tele that is different from... well any telecaster body?
Normally the 22nd fret is just a lip like extension of the fretboard that sits over the pickguard. It's no problem to make such a neck and I bet there's such available in shelves.
Check Allparts for example. There's plenty of 22 fret tele necks there. Warmoth, any of the small manufacturers.
If you remove the noisy stuff inside the piano it makes a great house for a dog.
varakeef is offline   Reply With Quote
Deluxe Nashville Tele nut telo Telecaster Discussion Forum 4 August 15th, 2009 10:41 AM
Thickness of MIM Nashville Deluxe tele neck, 1st and 12th fret? psychotelepathic Tele-Tech 9 September 9th, 2008 08:07 PM
Nashville Deluxe Tele TelePaul101 Tele-Tech 4 July 5th, 2007 06:52 PM
Fret buzz nearly everywhere 72 Tele Deluxe RI MIM mtnjam74 Tele-Tech 9 June 8th, 2007 04:43 AM
What fret wire on the American Deluxe Tele? crawdad Tele-Tech 0 April 13th, 2006 02:28 AM
