Old October 25th, 2009, 09:59 AM   #1 (permalink)
Where should a beginner start?
I've made a few basic mods to my guitar including changing out the pickups. I've noticed that there are many subtle changes that many people recommend that include changing Caps, Pots, wiring configurations and combinations of all. There appears to be lots of great information on this forum but some of it hard to follow for a newbie. Can anyone recommend a resource that can help me get started and understand the effect of making some basic changes?
Many thanks.
Tupple is offline   Reply With Quote
Old October 25th, 2009, 10:40 AM   #2 (permalink)
kyle1167's Avatar
This is probably the best place. If there is something that you don't understand or can't quite follow don't be afraid to say that. Everyone here was new to this at one time so they will understand if you have any problems.
There is such a wealth of knowledge here just don't be afraid to use it.
My Guitars
Guitar Projects
kyle1167 is offline   Reply With Quote
Old October 25th, 2009, 01:45 PM   #3 (permalink)
Thanks. Much appreciated.
Old October 28th, 2009, 03:30 PM   #4 (permalink)
straight up. If you want to get the best out of your guitar learn to tweek the neck and set it up properly. If you run zero or next to zero relief you will get more sustain out of your piece since vibrations are being more directly sent into the body. And there is a sweet spot for every guitar. On mine as little as 1/8 turn on the truss rod would change the resonance. Then you have pickup height adjustment which will affect how the pickups you have sound. Then you have pick attack and other personal issues. I can't say i have ever had to tear into the guts of a guitar except to fix broken things except when i was first starting out and modded an old 3 pickup hagstrom I to work like a strat. I shoulda bought a strat and not tore up a cool piece.
anacephalic is offline   Reply With Quote
Pure beginner needs help Please TeleRon Tab, Tips, Theory and Technique 11 September 5th, 2008 08:46 AM
Beginner Ignorance jpm1596 Tab, Tips, Theory and Technique 2 July 16th, 2008 07:18 PM
Amp kit for beginner tlsmack Amp Central Station 12 April 8th, 2007 12:57 PM
New here. Need beginner equipment help. rick268 Telecaster Discussion Forum 20 September 17th, 2005 05:09 PM
Beginner WAH The Bone The Stomp Box 3 May 25th, 2004 06:35 AM
