Old October 18th, 2009, 12:05 PM   #1 (permalink)
Removable Truss Nut on Affinity Tele?
I picked up a used Squier Affinity Tele that has a pretty stripped out nut on the truss rod. I was able to grab enough steel to make the adjustments I needed, but I'd like to replace it before it's totally stripped and becomes an even bigger pain. The neck is very nice and I'd like to salvage it.
Does anyone know if this is possible on this guitar, or is it a one piece rod that can't be fixed?
KevinV is offline   Reply With Quote
Old October 18th, 2009, 12:30 PM   #2 (permalink)
rhomco's Avatar
You can fix it but
It will be expensive. You have to open the hole in the headstock to unscrew the old one, back bore the hole slightly deeper so the new nut will have more threads to grab. It is not hard to do IF you have the
"Truss Rod Rescue Kit" from Stewmac but it costs more than a new neck if you want to do it yourself. I know this how
rob
If I won the Lotto.... I'd just build (OK, OK Assemble) guitars and sell them till the money ran out
rhomco is offline   Reply With Quote
Old October 18th, 2009, 12:40 PM   #3 (permalink)
Thanks, Rhomco. That looks like an ingenious idea, and as you said, a bit expensive. Hopefully it doesn't come to that.
I should clarify my earlier post. I don't believe the threads are stripped on the nut, or on the rod, just the nut where the hex key mates. I'm wondering if the Affinity has a nut that is replaceable if I can get the existing one out so that I have a fresh nut to work with.
I've never replaced a truss nut, so I'm not sure how many designs there are, and if the cheaper imports like the Affinity have an "all in one" system that can't be repaired by replacing individual parts.
Old October 18th, 2009, 01:02 PM   #4 (permalink)
KevinB's Avatar
Loosen the strings and remove the nut completely. Check the threading on the rod with a gauge. With it being a Squier it might use a metric thread and that may be a problem. Otherwise, new truss rod nuts are available inexpensively in 8-32 and 10-32 threads from places like Stew-Mac and LMII.
Old November 1st, 2009, 12:01 AM   #5 (permalink)
I'm pretty sure it will be metric. I've still been unable to locate a replacement for it. The one on it is still working, but it really needs replaced before it strips out.
Old November 1st, 2009, 10:04 AM   #6 (permalink)
rhomco's Avatar
Sounds moe like
you have a stripped/stripping hex key hole if the "threads" are good on both the nut and the truss rod. If that is the case, you just need a new nut.
Rob
Removable baffle in Princeton baz-t Amp Central Station 7 March 21st, 2009 10:04 PM
Are Bigsby's removable? SirenSilently Telecaster Discussion Forum 14 June 29th, 2008 06:57 PM
Affinity BSB truss rod adjustment? DavidP Tele-Tech 0 May 11th, 2008 03:46 PM
Machine screw inserts for building a removable neck Tele. galtjunk Tele-Tech 11 April 19th, 2006 12:30 PM
SFVR removable grillcloth frame Tele295 Amp Central Station 6 December 9th, 2004 03:13 PM
