Old September 5th, 2009, 01:45 PM   #1 (permalink)
Big Alex's Avatar
72 Tele custom Jack replacement
Mine has the circular jackplate with no screws. Do I have to remove the pickguard to asses the jack?
Big Alex is offline   Reply With Quote
Old September 5th, 2009, 01:57 PM   #2 (permalink)
KevinB's Avatar
Yes, you do. Also remove the external retaining screw on the jack socket itself and then you can withdraw the socket through the route under the control plate.
Old September 5th, 2009, 02:44 PM   #3 (permalink)
Guitarmadcat's Avatar
No, you don't. So long as your OK with removing/ replacing the retaining clip in the socket channel.
Remove the nut and cup then, using snipe-nose pliers, remove the retaining clip and the socket will come out on about 3" of wire.
If you're unhappy about messing with the retaining clip, then you will have to go in via the scratchplate (pickguard in Yankese!), or control plate - depending on which Custom you have.
Guitarmadcat is offline   Reply With Quote
Old September 5th, 2009, 06:35 PM   #4 (permalink)
KevinB's Avatar
IMHO removing the pickguard is a whole lot easier
Old September 6th, 2009, 06:56 PM   #5 (permalink)
Big Alex's Avatar
I guess IŽd better remove the strings do this work right?
Old September 6th, 2009, 07:06 PM   #6 (permalink)
jwells393's Avatar
I'm with KevinB on this one. Removing the jack plate clip would be a big mistake unless you're planning an Electrosocket replacement.
Old September 7th, 2009, 09:56 AM   #7 (permalink)
KevinB's Avatar
You will at least have to loosen the strings. You may (or may not) have to remove them. You just have to get the pickguard moved enough to get at the socket.
The problem with removing the retainer clip, is that it wasn't exactly Leo's best ever design! You could certainly get it out with a pair of pliers, but putting it back in securely with pliers is not easy. If yours is stable right now, I wouldn't mess with it. There are tools available - like the one below from StewMac, or you can make one yourself - to put these clips in properly, but to do it you need to have the socket out.
Advice for Middle PUP replacement for a custom tele Hellbender Telecaster Discussion Forum 0 March 12th, 2009 09:49 PM
my ass from a hole in the ground: which is which? (jack replacement help) jivetrain Tele-Tech 6 September 10th, 2008 11:25 PM
Cube 60 jack replacement dogcityrocker Amp Central Station 0 February 27th, 2007 08:30 AM
input jack replacement woes -- help! curbinati Telecaster Discussion Forum 4 June 30th, 2005 10:20 PM
Replacement for tele custom neck humbucker? gringo perdido Just Pickups 4 October 30th, 2003 08:20 PM
