1 Hotrail, 1 Volume, 1 Tone with Gibson style 3 way switch?
Hello, I am making a lap steel guitar and I would like to wire it this way:
http://www.seymourduncan.com/support...tic=esquire_hb I found a post here where someone wanted to do a similar thing except the other way, switching from a gibson 3 way to a blade: http://www.tdpri.com/forum/tele-tech...ele-style.html I'm hoping I could get a similar explaination about how to translate the blade style switch used in the wiring diagram above to the gibson style switch. Thanks. - anthony |
Need gibson toggle switch such as this one from Stewmac.
![]() HTH & YMMV EDIT: should have drawn it as a hotrail, too late now EDIT2: also forgot to add the ground wire to the toggle switch |
thanks...and sorry I wasn't totally clear
Thanks for the quick response.
a couple clarifications: 1. the type of switch I have is like this one: http://www.smarter.com/guitar-access...pi-306696.html which has 4 connections on the bottom (similar to the gibson type described in the seymour duncan diagram: http://www.seymourduncan.com/support...atic=3ws_trans) Sorry, I'm really new to this and need it all explained, including where the ground wire would go. I can follow the directions but I don't understand the "why?" well enough to adjust to anything not clearly addressed in a diagram. thanks again. |
Looks like 3 lugs on that switch in the first link, if so you can't use that. If you have one of those on/on/on toggle switches (in the second link you gave) then you can use that. I guess you'll have to buy another switch.
An explanation of the on/on/on toggle is given in the Stewmac link I provided. If you finalise on your switch post the details - I'll then modify the diagram to suit that switch. EDIT: here is an update
Thanks cc9cii. I'll need to get a new switch, so I think I will get the one you recommended from stewmac if my local electronics store (DuVac in pasadena) doesn't have one.
So I need a DPDT switch right? What does the "throw" part refer to? I think I understand the pole part? Thanks again. |
| Gibson Style Switch to Tele 3 Way conversion? | TheBear | Tele-Tech | 4 | August 18th, 2009 12:33 AM |
| bypass tone and volume switch? | old_picker | Just Pickups | 2 | July 28th, 2009 04:58 AM |
| 2 Humbuckers 2 Volume 1 Tone 3-way Lever Switch (tele style) | metalmaniac23 | Tele-Tech | 3 | April 24th, 2009 01:23 PM |
| Two pickups in series - possible with Gibson-style toggle switch? | RomanS | Tele-Tech | 8 | November 3rd, 2008 04:14 PM |
| Gibson style 3-way switch on a Nocaster? | Tysinger | Telecaster Discussion Forum | 11 | September 13th, 2007 11:30 PM |
