Old September 3rd, 2009, 01:13 PM   #1 (permalink)
'52 RI w/neck shim
I have owned this '52ri for 5 years or so and a couple months back decided to put a bigsby on it. BIG MISTAKE. So I had it removed. In the process of adding the Bigsby the neck was shimmed. But upon removal the tech (different than guy who added Bigsby) did not remove the shim.
The set up seems fine-- intonation is spot on, action is good ,etc. But.... something is not right.
The stock guitar had no neck shim.
I swear the guitar plays differently and sound differently with the shim and I am on the verge of removing it.
Am I crazy? I will almost certain remove the shim just for my own sanity!
Thanks for your opinions...
mel_jr
mel_jr is offline   Reply With Quote
Old September 3rd, 2009, 01:43 PM   #2 (permalink)
boris bubbanov's Avatar
You're not crazy for disliking the Bigsby on there. Something is really lost.
No doubt the shim needed to come back out - it was only in there to facilitate the installation and setup of the Bigsby.
I'd take the shim out without a moment's reservation.
IMO part of the reason the Bigsby left you cold, was the shim itself. Got no use for shims, except as a diagnostic tool or for short term remedial purposes.
Substantially shimmed guitars are 4 day old baked goods. I get images of trying to rehabilitate the suspension on a crippled 1950's british sports car and catching a basketfull of shims as they fall out once the bolts are loosened. Yiiiii.
When i listen
Old September 3rd, 2009, 01:59 PM   #3 (permalink)
Boris,
I figured the shim was the culprit. Is there any trick to removing these?
I don't really want to have a tech do it -- I suppose all that would need to happen after the shim is out is to lower and intonate the bridge.
Thanks very much!
Old September 4th, 2009, 05:56 AM   #4 (permalink)
Twang Tone's Avatar
Originally Posted by mel_jr View Post
Boris,
Thanks very much!
Exactly. Take the neck off, remove the shim, replace the neck, and re-string (with a new set). Then lower the action to where it's comfortable, then adjust the intonation accordingly.
Thanks,
TT
Ridicule is nothing to be scared of!
Twang Tone is offline   Reply With Quote
Old September 5th, 2009, 12:47 AM   #5 (permalink)
No more shim
Today I removed the neck on the tele and found a little cardboard shim made out of cardboard Boomers guitar string packaging. The guitar sounds better, plays better. Nice to have my old tele back again.
Thanks for all your helpful comments.
mel-jr
How does a neck shim help PeteG45 Stratocaster Discussion Forum 7 October 3rd, 2008 08:56 PM
How much is too much for a neck shim? martyb1 Tele-Tech 5 March 18th, 2008 11:22 AM
How do I tell if I need a neck shim? SinnerBoy61 Tele-Tech 6 March 1st, 2007 07:29 AM
neck shim questions div Telecaster Discussion Forum 20 September 14th, 2005 08:52 PM
How many use a neck shim? Brewbaker Stratocaster Discussion Forum 8 April 14th, 2005 08:27 PM
