Old July 4th, 2009, 03:25 AM   #1 (permalink)
Help needed to wire my Telecaster in parallel!
Hi, I wonder whether anyone can help me or direct me to a schematic for this, I can't get it to work correctly.
I am using a single coil dimarzio in bridge, my issue is with my Seymour '59 in neck. i am wanting to wire it to my push-pull tone pot to switch from series to parallel. 3 way switch will remain neck/neck-bridge/bridge no matter whether neck is series or parallel, and i am using a Sprague .22 capacitor. I'm using a 250k volume, and 1Meg tone pot.
I have tried to wire it by using fender's standard telecaster wiring schematic, although my 3-way switch tabs come off differently. in Fender's diagram, the four tabs on the left side are higher. my switch's tabs are higher on the right side. if that makes sense. so i'm not totally sure how to wire my 3-way either.
so i am using that schematic, with a push-pull pot wiring diagram http://www.guitarnuts.com/wiring/sw3.php (Series/parallel switching (using push/pull on volume or tone)
the bridge pickup seems to be working fine, but the neck ('59) sounds parallel no matter what the push-pull switch is doing, and the middle position on the switch (neck/bridge) is silent, no signal there.
Thanks for any input, I am at a bit of a dead end!
amswafford is offline   Reply With Quote
Old July 4th, 2009, 03:35 AM   #2 (permalink)
Deaf Eddie has a site full of wiring diagrams. See here.
cc9cii is offline   Reply With Quote
Help needed with wiring my Tele for parallel! amswafford Tele-Tech 0 July 3rd, 2009 06:20 AM
Wire advice needed Tommy Tourbus Tele Home Depot 0 March 6th, 2009 11:51 PM
how to wire series parallel using mini toggle ? cbnutt Telecaster Discussion Forum 2 December 30th, 2008 09:03 PM
Can I wire a 4way w/ parallel out of phase? Newfie_J. Telecaster Discussion Forum 4 July 29th, 2007 08:06 PM
Telecaster Fret Wire Gauges Hockey Rocker Telecaster Discussion Forum 2 July 2nd, 2007 08:01 AM
