Old July 2nd, 2009, 07:50 PM   #1 (permalink)
Identity of old "weird" Tele Bridge pu - double coil
Hello,
does someone know the brand or anything else about this pickup?
I bought it together with lots of other broken pickups, some working some not.
This one is quiet unusual, it has two coils. It has 5 conductors, green, white, black, red and a not isolated ground wire. DC-resistance is 16.04 kOhm both coils (green/red), 8.06kohm upper coil(red/black) and 8.03kohm lower one (white/green). The upper coil has staggered 0.193'' diameter magnets, the lower coil non at all. I don't know, if this makes sense . I never tested this pu in a guitar. I think, they gone lost . Another detail is the metal plate on the bottom/sides of the upper coil, it looks as if it was glued to the top of the lower coil.
I will be very happy about any information about this pickup,
best regards
Till A
Gokarna is offline   Reply With Quote
Old July 2nd, 2009, 08:05 PM   #2 (permalink)
steadyriot's Avatar
God thats strange, nowi want to know what that is!
the day that I die will be the day that I shut my mouth and put down my guitar
steadyriot is offline   Reply With Quote
Old July 2nd, 2009, 08:08 PM   #3 (permalink)
Talmir's Avatar
I think that this might just be a pup hack job.. someone lost the springs to mount the pup at the bridge at some point and instead of replacing them he took a broken pup and hacked them together to get it to the right height from the bottom of the route..
my take at least :P
Talmir is offline   Reply With Quote
Old July 2nd, 2009, 10:09 PM   #4 (permalink)
iansmitchell's Avatar
Would make one helluva slide pickup...
Please do not insinuate anything sexual from that.
iansmitchell is offline   Reply With Quote
Old July 3rd, 2009, 02:01 AM   #5 (permalink)
GilmourD's Avatar
Given the plate between the two coils that's definitely a pickup designed to be noiseless. I just don't know what it could be.
Good deals: Joel Terry
Layla
Skye
Sunny
Wally
Franky
Honey
Wolfy
GilmourD is offline   Reply With Quote
Old July 3rd, 2009, 09:34 AM   #6 (permalink)
Oldschoolwax's Avatar
That looks Like a Dimarzio stack construction, I have one here for a Strat on the table, two pieces looks like they may have been waxed together but are now separate. I pulled this from the bridge of a 73 S to replace the original that was ( luckily ) kept in the case.
~Michael
Matter cannot be created or destroyed, nor can it be returned without a receipt.
Oldschoolwax is offline   Reply With Quote
Old July 3rd, 2009, 09:44 AM   #7 (permalink)
Hi, thanks you very much for these first replies
my take at least :P
You might be right, the Tele "baseplate" construction looks quiet selfmade
~Michael
Michael, what guitars is a "73 s", 1973 Stratocaster ?
To all viewers: Is it possible at all, that the lower coil gives a signal to the amp without having pole-pieces / magnets.
Best regards,
Till
Old July 3rd, 2009, 09:54 AM   #8 (permalink)
I'd be glad to take real pictures with my camera tonight and email them to you if you send me your e-mail in a PM. ( I just pulled this apart and did it with my cell phone to show you it was the same, it also doesn't day Dimarzio on the bottom, it says it inside the cover it mounted in. ) The bottom coil most likely is just reverse wound and helps cancel out hum produced in the local environment.
Yes 1973 Stratocaster, Pup from the 80's I believe...
Old July 3rd, 2009, 09:58 AM   #9 (permalink)
Willkommen to the forum Gokarna! =)
~Michael
Old July 3rd, 2009, 10:14 AM   #10 (permalink)
Hi Michael,
thanks for your welcome and also the quick reply.
Sorry, I haven't seen immediately, that you've already made a picture of your pickup. There's no need for a second one - that is the same kind of pickup, just with this Telecaster bridge baseplate.
Only one question left: Does your pickup has magnets in the lower coil (if you can see that)?
Best regards
Till A
Old July 3rd, 2009, 05:03 PM   #11 (permalink)
Nope, same as your's sits on a black plate also, just a coil, no magnets.
Vintage Vibe "Single Coil Pickups for Tele Style Guitars" MMJeronimo Just Pickups 2 June 8th, 2008 12:11 PM
He's got the matching body, too... Severely weird "tele" ebay tpaul Telecaster Discussion Forum 15 September 28th, 2007 09:38 PM
my kid says my Tele sounds "weird"! jhundt Telecaster Discussion Forum 7 February 19th, 2007 03:55 AM
"Vintage Style Tele Single-Coil Pickups" kenomajas Just Pickups 3 June 13th, 2005 10:39 PM
"bridge" vs "chorus" non-tele content stevedenver Telecaster Discussion Forum 25 February 2nd, 2005 10:26 PM
