'72 custom RI pot value query
Hi, I've read several people recommending upping the value of the HB pots to 500k to cure a 'muddy' sound.
Question: if you have the pots dialled to 10 (which is where I normally have them) does the value of the pot make any difference at all? I would have expected that the pot is simply by-passed when on 10, so there should be no difference. Can anyone confirm from experience that there is actually a difference? I will say that I have noticed an improvement from lowering the HB a few millimeters. It's not big, but definitely has more chime now. So at least that's not a myth |
Yes, the value of the volume pot will have an effect when you dime it. Assuming the volume pot is wired in a standard fashion, when the pot is full on, the total value of the volume pot is in parallel with the pickup. As you turn the volume pot down, a larger portion of the pot is in series with the pickup, and a smaller portion of the pot stays in parallel. Because of this, the value of the volume pot matters, even when it is full on. The larger the value of the volume pot (up to a point), the brighter the tone will be when the volume is full on. Also, the larger the value of the volume pot (up to a point), the more dramatic the treble rolloff will be as you turn the volume down.
When you say "matched", are you asking whether the volume and tone pots should each by 500K? There is no rule that says they must be the same. In fact, you might want them to be different. A volume pot is wired in a manner different from a tone pot. The volume pot has a portion in series, and a portion in parallel, with the pickup. A tone pot is in series with the pickup. The only thing that changes, with a tone pot, is how much of that pot is in series. Thus, if you had a 500K tone pot, but always kept it turned down so that only 250K ohms were left, it would be the same as replacing the tone pot with a 250K pot, and leaving it dimed. I wouldn't do that, though, because it doesn't leave you with the option of increasing the brightness, should you need it. It might make a difference to replace the tone pot with a 1Meg pot, if you don't think it is bright enough at full volume and full tone. A 1Meg tone pot (with the same tone cap), full on, will be brighter than a 500K tone pot, full on. You can turn the 1Meg pot down to the point at which the tone control sounds just like a 500K tone pot, full on.
Jim, thanks, I really appreciate your reply. I don't have a circuit diagram, so I'm a bit in the dark.
As I'm a Brit, we don't have the expression 'dimed' - is that 0 or 10? and is 10 where the series resistance is 0 or 500k? Also, when you turn the vol pot down and you get more of the pot in series, why does that not change the tone? sorry for all the dumb questions! thanks Phil |
| p-90 query | Jode | Just Pickups | 12 | August 26th, 2008 02:12 PM |
| UK E Bay query | blue metalflake | Telecaster Discussion Forum | 6 | January 25th, 2007 08:15 PM |
| Mac Computer Query | Oskar | Bad Dog Cafe | 22 | March 22nd, 2006 04:15 PM |
| EMG SA and SPC query | Great Ape | Just Pickups | 5 | August 25th, 2004 09:08 PM |
| Pedal query | Paul B | The Stomp Box | 0 | October 30th, 2003 04:06 AM |
