Old June 2nd, 2009, 04:48 PM   #1 (permalink)
More useable tone pot advice
Replaced the pots in my MIJ Tele with 2 x alpha audio pots (B) (didn't want to have to buy new knobs or control plate for CTS pots). Wired it up according to the standard tele diagram at Seymour Duncan http://www.seymourduncan.com/support...=standard_tele
Everything seems fine, except the tone pot really only works for the first 1/3 from full cut. It goes from very bassy to (apparently) full open in that 1/3 turn.
Is there any way to make it more gradual and therefore more usable without switching it out for a linear pot?
Thanks.
gsh1968 is offline   Reply With Quote
Old June 2nd, 2009, 04:52 PM   #2 (permalink)
PhatTele's Avatar
If I read that post correctly, you probably got the wrong pots. Alpha pots w/a "B" on them are linear taper not audio taper. You want the audio taper.
Old June 3rd, 2009, 06:32 AM   #3 (permalink)
Wouldn't the way the tone is acting suggest it is an audio/log taper? The supplier specifically states the "B" pots are volume pots. (I guess I should have simply bought one B and one A pot as suggested instead of getting "creative")
I've read it is possible to make a log pot act linear by adding a resistor, but I'm finding conflicting info on value of the resistor and actual connections.
I'll order another pot anyway - I just wanted to see if there was an easy fix I could do today.
Cheers.
Old June 3rd, 2009, 06:07 PM   #4 (permalink)
RomanS's Avatar
Nope, if there's a "B" on there, it is a linear pot!
What cap value do you have on that tone pot? I find 22nF tone caps more useful than 47nF, because they give you a much wider range of adjustment (sure, with the tone pot totally turned down, you won't get as muffled a tone as with a 47nF cap - but is anybody really using the tone pot totally turned down?)
Old June 3rd, 2009, 08:48 PM   #5 (permalink)
surfoverb's Avatar
I was gonna say the same thing when I saw the title. .022
"You released the ******* fury!"
Old June 4th, 2009, 04:59 AM   #6 (permalink)
I'm using .047. I'll get a.22 along with the new pot and see how that fares.
Thanks.
Old June 4th, 2009, 05:11 AM   #7 (permalink)
RomanS's Avatar
Probably just a typo of yours, but make it .022uF (=22nF).
Old June 4th, 2009, 06:06 AM   #8 (permalink)
Indeed a typo, cheers.
Old July 2nd, 2009, 12:29 PM   #9 (permalink)
Thought I may as well update this.
I finally got round to ordering a few things from Axesrus, including a replacement "A" pot.
There's a significant difference, ie now the tone knob actually has more than 1/3 useful spread, even though the final 1/3 to full cut still seems to have the most significant/noticeable reduction.
May play around with different caps and wiring schemes at a later date, but it'll do for now.
Cheers.
Old July 2nd, 2009, 08:15 PM   #10 (permalink)
RomanS - I thought the higheryou went the MORE tone you got cause less was being rolled off.
Do I have it backasswards?
PB
PhatBoy is offline   Reply With Quote
Old July 3rd, 2009, 05:44 AM   #11 (permalink)
RomanS's Avatar
Nope, we're both right:
-) with a higher value cap (47nF), you can "roll off" more tone than eg. with a 22nF cap, you can make the tone even darker/more muffled (as I already mentioned in my first post).
-) BUT: I don't think anybody ever uses any guitar with the tone pot turned down all the way, as even a Tele on the bridge PU would sound way too muddy & muffled that way; most people probably use only the first third or half of the range of the tone pot...
So, with a 22nF cap, you need to turn down the pot more than you would have to with a 47nF cap, for the same result - consequently, you can set your tone more precisely with the 22nF cap, because 10° of turning will cause less difference than with a 47nF cap, the adjustment will be more gradual (and that's what the original poster was looking for!) - you don't have to be as careful/precise when setting the control; and that's what I meant with "wider range of adjustment"!
Old July 3rd, 2009, 10:43 AM   #12 (permalink)
surfoverb's Avatar
and now that I use .022 I use the whole pot, even with the neck PUP and the tone rolled all the way off it doesn't sound overly dark.
TRRI mods and tone experience/advice Los Doggies Amp Central Station 16 July 17th, 2008 01:49 PM
seeking advice on tone woods Lafayette Telecaster Discussion Forum 26 August 10th, 2007 02:58 PM
Tone Control Idea - any advice? chickenpicker Tele-Tech 4 November 22nd, 2005 08:02 AM
authentic tone - replacement pickup advice please snap Tele-Tech 3 December 2nd, 2004 01:17 PM
Strat tone advice Bone Machine Stratocaster Discussion Forum 28 May 29th, 2003 07:54 AM
