Old May 30th, 2009, 02:29 PM   #1 (permalink)
czech-one-2's Avatar
spezel tuners-to wrap or not wrap?
i just aquired a strat with these already installed and noticed the previous owner wound the strings on the post several wraps each string.
is this the prefered method?
or do you just pull em' straight through?
if you wrap them,do you lock them before or after winding?
ive heard of alot of string breakage problems if you over tighten the locking wheel.how tight is right?
any opinions?
czech-one-2 is offline   Reply With Quote
Old May 30th, 2009, 03:35 PM   #2 (permalink)
Al Watsky's Avatar
Do not wrap. Tighten before winding. Hand tight.
Livin' in the Past ,Present and Future
is takin' up all my time..........
Al Watsky is offline   Reply With Quote
Old May 30th, 2009, 04:13 PM   #3 (permalink)
you should end up with about 3/4 of a wrap when tuned. it is stable and holds tune extremely well.
guitarman_nebr is offline   Reply With Quote
Old May 30th, 2009, 04:22 PM   #4 (permalink)
that was fast!
thanks you guys,i'm glad you just pull em through as i'm lazy and like the idea of not having to wind em!
Old May 30th, 2009, 06:40 PM   #5 (permalink)
boris bubbanov's Avatar
Yes, I like 1/2 to 3/4ths of a wrap.
That way I can take off, then re-install a string if need be. Half a wrap on a hardtail, 3/4 of a go-round on a trem guitar.
I agree with Al, hand tight, you may use a cloth if your grip strength is diminished. Use a tool and you will break 'em.
When i listen
Old May 30th, 2009, 08:55 PM   #6 (permalink)
rhomco's Avatar
According to Sperzel
You first rotate the string hole in the tuner post to about 5:00 in line with the string path. That is 11:00 at the top and 5:00 at the bottom facing the nut. Then load the string just slightly slack and lock it down. Now tune up and you will have about 3/4 wrap. I love em.
Rob
If I won the Lotto.... I'd just build (OK, OK Assemble) guitars and sell them till the money ran out
rhomco is offline   Reply With Quote
Wrap-around bridge help tdu Bad Dog Cafe 20 May 18th, 2009 12:08 PM
Strat Lap Wrap rdchapman Just Pickups 3 April 30th, 2009 11:04 AM
Wrap that Rascal GuitarJonz Telecaster Discussion Forum 8 May 10th, 2006 12:15 PM
Why doesn't the TDPRI wrap? petebradt Forum Problems & Issues 1 June 12th, 2004 03:16 PM
The Waylon Wrap Gary Lamb Telecaster Discussion Forum 9 March 13th, 2004 12:58 PM
