Shimming a neck
I've read a lot of posts about fret buzz and installing a shim to correct it. What I don't understand though is how shimming a neck is any different to adjusting the saddle height. Shimming a neck at either end of the neck pocket increases or decreases the angle of the neck. However it also affects the string angle, since they touch the neck at the nut and as the other end of the strings is at the bridge, the overall effect is to alter the string angle relative to the neck. If you adjust the saddle height, then (as long as there is enough travel possible given the saddle screw size) you will also alter the angle of the strings relative to the neck.
If you have a certain action, say 5/64 on the low E at the 12th fret, then after shimming the neck the saddle must be adjusted to maintain that action. So, my question is, doesn't shimming have the exact same effect as adjusting the saddle height, with the exception that shimming increases the range of saddle screw adjustment that is possible? Hope I've been making sense.
Quiet desperation is the English way... |
You make perfect sense.
Shims are for when your saddles are maxed-out either way (high or low). Sloppy neck pocket routing and/or a badly made neck heel are the main culprits if you discount paint build up. A well-made guitar shouldn't need a shim.
That would be true if the neck is flat but they aren't the relief in the neck means that its not quite as simple. I just set up a tele that had a shim in it the action was 2mm but it buzzed on the high frets ? I removed the shim and set the neck back to flat lowered the action to 2mm no buzzes. So if the neck is slightly shaped with a curve by shimming the neck to tilt back you raise the saddles but also raise the end part of the neck. If you see what I mean.
#4 (permalink) | |
#5 (permalink) | |
The issue is the height of the strings over the face of the instrument, and by implication, the height of the saddles over the face of the instrument. If these are within acceptable limits, no shim is needed.
A really nice touch for a setup is to have all the saddle height screws flush (or close to) the tops of the saddles. |
a shim can also help if your action is fine on the first 12 frets but breaks high on the upper-register frets (at least it did for me).
#10 (permalink) | |
If you want more clearence (height) in the picking area, you'll have to rise the saddle. But saddle adjustment also affect the action in the fretting area. So if you want high picking area, you'll have to live with high fretting action; If you want low fretting action, you'll have to live with low picking area. You can solve (resolve?) this dilemma by shimming the bridge end of the neck pocket. Tall bridges (saddle) need a little bit of neck angle to maintain low fretting action. I learnt this lesson when I put a Floyd in my 1st guitar (RIP) back in the 80s!
I met with some energy people. I realized a tepee is pretty advanced compared to what they did. - Frank Gehry |
#11 (permalink) | |
Some feel that the height of the bridge can affect the tone on some guitars, maybe due to altering the break angles, maybe due to the length of screws holding the saddles off the guitar, so shimming would allow you to play with that if you were really really bored. Changing the access to the upper frets? If you use a wedge shaped shim lining the neck pocket, then geometrically not possible, a shim does not change the relief of the neck, 2mm is 2 mm and the shape of the neck is the same. If you use a bit of chunk at the body end only, and screw the neck in really tight, maybe you will cause some extra curvature between frets 16 and 21, which could theoretically give the results Leebman speaks of. This isn't really what shimming is all about though, and high fret problems might better be addressed with some fret work? However, if it fixes the problem, it's all good. |
#12 (permalink) | |
| Neck shimming question | jessecoffee | Tele Home Depot | 4 | December 26th, 2008 07:10 AM |
| neck shimming question | jessecoffee | Tele-Tech | 10 | December 22nd, 2008 11:21 PM |
| shimming neck for a higher action. | dankomal | Stratocaster Discussion Forum | 5 | October 3rd, 2008 12:18 PM |
| Question on shimming neck? | Tele The Truth | Tele-Tech | 9 | January 25th, 2006 09:46 AM |
| shimming neck for bigsby | LipstickTUBE | Telecaster Discussion Forum | 10 | November 6th, 2003 07:10 AM |
