Old February 8th, 2009, 11:41 PM   #1 (permalink)
HoodieMcFoodie's Avatar
Out of phase switch not switching phase.
Hi there,
I've just installed a SD 59 SH-1n (2 wire) in the neck and a SD Vintage Stack STK-T3b (5 wire) in the bridge of my partscaster. I've got an out of phase switch located between the vol & tone pots and have the bridge pickup wired to switch the phase, using the wiring diagram at the Seymour Duncan website.
The problem I have is there seems to be no appreciable difference when the switch is in one position or the other, just a very slight change in tone. No volume drop, no nasal tone - nuttin'.
What's going on here? Can anyone shed anylight on the matter please?
All input is gratefully appreciated.
Regards,
Hoodie
P.S. The bridge pup has a brass baseplate if that helps
Why use a big word, when a diminuative one will do?
HoodieMcFoodie is offline   Reply With Quote
Old February 9th, 2009, 07:42 AM   #2 (permalink)
Anyone...anyone... Beuller... Beuller... Beuller?
Old February 9th, 2009, 01:13 PM   #3 (permalink)
Check your wiring again......Hard to say without hearing it...Good luck...Cheers
TeleDrifter is offline   Reply With Quote
Old February 9th, 2009, 03:46 PM   #4 (permalink)
udimet720's Avatar
Isn't your bridge pup a vertical humbucker design? Hence the name "stack"...
Switching the wires won't make any change (I think).
udimet720 is offline   Reply With Quote
Old February 9th, 2009, 04:31 PM   #5 (permalink)
mkern's Avatar
A dumb/obvious question first then some insight:
I assume you are trying the phase switch when the pup selector switch is in the middle position right?
I added a phase switch to a tele and decided to connect the phase switch to a 2-wire bridge pup. It didn't work and acted like a kill switch. Did a little research and realized the ground to the brass plate would have to be resoldered in reverse. Said to self "Self, forget the bridge" and proceeded to rewire to the 5-wire neck bucker. All was nasally after that. It doesn't matter which pick-up you phase to get the desired sound so I recommend the 5-wire neck pup on your guitar.
mkern is offline   Reply With Quote
Old February 9th, 2009, 06:14 PM   #6 (permalink)
Yes it is a vertical stack. But I am trying to put it out of phase with the other pickup. Would being a stack make a difference?
Correct. I understand the basic principle of it so I am aware that the 3-way switch need to be in the middle position.
Thta's what I'd read here when researching, so that's what I did.
Old February 9th, 2009, 06:15 PM   #7 (permalink)
twangcaster1's Avatar
Yeah, what he said.
Louisiana Twangmaker
twangcaster1 is offline   Reply With Quote
Old February 9th, 2009, 06:35 PM   #8 (permalink)
Which diagram did you use?
Jim.Collins is offline   Reply With Quote
Old February 9th, 2009, 07:24 PM   #9 (permalink)
OK.
This one came with the SH1-n
This one came with the STK-T3b
So I used the phase switching bit from the first one, assuming that the wire colours meant the same thing on both pups...
Old February 9th, 2009, 08:32 PM   #10 (permalink)
So the bridge pickup's red and white leads are soldered together, and that joint is taped off. The black and green leads go to the DPDT switch. (The bare lead goes there, as well, but it is permanently tied to ground.) From the DPDT switch, there are two output leads. One goes to the selector switch and the other goes to ground. As long as the DPDT switch is wired correctly, this should work, and you should hear a significant difference when both pickups are selected.
Old February 9th, 2009, 09:03 PM   #11 (permalink)
Yep, that's exactly how I've done it.
I'll double check it tonight when I get home, but I'm 99.5% sure I've got it right.
Unless I've cooked the switch during soldering, but them it wouldn't work at all, right?
Old February 10th, 2009, 08:42 AM   #12 (permalink)
I had a look at it, but it seems to be wired OK.
I guess I'll replace the switch with a new one and see if that makes any difference...
Here's hoping.
Old February 13th, 2009, 06:24 AM   #13 (permalink)
I think you may be right udimet. Today I took the old switch out. I thought I might have cooked it during the build. I put in a brand new DPDT switch, wired it up, checked it and guess what? It still sounds the same.
I think I'm gonna try a SD Antiquity II bridge pickup. 2 wire jobby. Surely I can get that to reverse phase.
