Old January 21st, 2009, 08:08 PM   #1 (permalink)
cacibi's Avatar
Stripped truss rod nut
Well - it looks like I've got stripped truss rod not ON MY FAVORITE NECK no less!
Is it even possible to just replace the nut? Can a shop just drill out the walnut plug wall, replace the nut and install and new walnut plug and drill for access?
For the details, this is Warmoth maple neck with headstock adjustment.
www.thegearspy.com
cacibi is offline   Reply With Quote
Old January 21st, 2009, 08:47 PM   #2 (permalink)
Are you certain the nut is stripped and not the threading on the truss rod? I have seen FAR more stripped bolts/threaded rods than I have nuts...
I believe the whole rod may need to be replaced/rethreaded. Someone else may be able to chime in and give their two cents (and I may be wrong).
LocustPlague is offline   Reply With Quote
Old January 21st, 2009, 08:48 PM   #3 (permalink)
jwells393's Avatar
Replacement truss rod nuts, washers and walnut plugs are available from certain authorized Fender repair shops. I got these from Music One Workshop.
If you don't have someone local whom you trust, I suggest you contact Larry Miletich at...............
http://www.musiconeworkshop.com/
You could send him the neck. He's a Fender Gold Level Master Technician.
Old January 21st, 2009, 08:49 PM   #4 (permalink)
charlie chitlin's Avatar
Good design would dictate that the truss rod material would be harder than the nut.
That way the nut could strip without damaging the rod.
Maybe you can get the nut out and find the threads on the rod intact.
charlie chitlin is offline   Reply With Quote
Old January 21st, 2009, 08:58 PM   #5 (permalink)
cacibi's Avatar
Many thanks!
I'm almost certain it's just the nut that's stripped. I bought a huge allen wrench set (metric and standard) on the way home to see if I can find anything that's close. It still got some 'squareness' to it so - maybe something will fit in there and do the job for a temporary solution.
www.thegearspy.com
Old January 21st, 2009, 09:00 PM   #6 (permalink)
jwells393's Avatar
By "stripped truss rod nut" what do you mean? Probably the hex hole is stripped from using the wrong size wrench. It's unlikely the threads in either the rod or the nut are stripped............. although anything is possible.
The Gripper from StewMac is a great truss rod wrench. It's got a tapered hex.
Old January 21st, 2009, 09:05 PM   #7 (permalink)
cacibi's Avatar
Yes the hex hole is stripped.
I did see that wrench from stewmac but - given the play when I put in a 1/8" hex, I honestly wasn't sure if it had enough taper to be of any help.
www.thegearspy.com
Old January 21st, 2009, 09:06 PM   #8 (permalink)
jwells393's Avatar
Try a 5/32 if your set has one. I recently replaced a truss rod and the new nut required a 5/32 in. hex wrench.
Oh, by the way, that new nut was from Warmoth. Maybe that's what they use in their necks.
Old January 21st, 2009, 11:14 PM   #9 (permalink)
VENDOR
mellecaster's Avatar
9/64 is also common to most Allen wrench sets...that might do the trick, if the 5/32 is a tad too big ?
Old January 22nd, 2009, 08:07 AM   #10 (permalink)
If you are unable to remove the nut with an allen key you could use an easyout . These should be available at an autoparts store. You hammer the easyout into the gole and use a wrench to turn the nut out.
Remove broken screws easily. Multi-fluted extractors are made from high carbon steel and the matching drill bits from high speed steel. This set contains 5pc extractor from 3/8" to 1/8" without skipping a size.
Did I mention I was cheap
Ed
spyderxxx is offline   Reply With Quote
Old January 22nd, 2009, 06:09 PM   #11 (permalink)
jefrs's Avatar
er, you can make you own by taking an old one that is slightly too big and filing or grinding it to a taper. My old Dad, a master tool maker, would quite often make tools like this for special jobs. I don't think that bashing the end of the truss rod will do it much good but you can tap the allen in with a toffee hammer.
