Old January 20th, 2009, 04:25 PM   #1 (permalink)
Wiring help needed: 1HB 1SC & 2 Controls
Hi everybody,
I am trying to figure out how to wire the controls for my current frankenstein tele derivate. The configuration looks like this:
1 humbucker (SD Seth Lover) at the neck, a single coil (G&L at the bridge, 1 vol and 1 tone control and a les paul style 3 way toggle switch on a Tele Custom style pickguard. The output jack is mounted to the pickguard as well.
The HB is to be connected to the volume pot only (ie no tone control) while the SC goes to both, volume and tone.
Help will be highly appreciated. To make it more convenient, I've sketched the components in the attached image, so may be you can simply draw directly into it...
Thanks upfront!
Be good,
Alex
klabuster is offline   Reply With Quote
Old January 20th, 2009, 04:31 PM   #2 (permalink)
jkingma's Avatar
I believe you will have to have 2 separate volume controls if you only want one pickup to be connected to a tone.
jkingma is online now   Reply With Quote
Old January 20th, 2009, 04:43 PM   #3 (permalink)
It can be done. I'd run your tone-controlled pickup over the tone pot *first*. Then from there, along with your other pickup, to the switch, then back to the volume & then the jack.
Know what I mean? I'm too lazy to draw...
Chris Leger is offline   Reply With Quote
Old January 20th, 2009, 05:15 PM   #4 (permalink)
jkingma's Avatar
Won't the tone pot affect both pickups in the middle position... even wired that way?
Old January 20th, 2009, 05:24 PM   #5 (permalink)
Hmm... you're right, it would. Only way to do it with a Gibson toggle, I'm afraid.
The tone would be cut out in the "humbucker-only" Position, but it would come on in the middle and SC positions because the outs are common on a Gibson toggle in the middle position.
Old January 21st, 2009, 12:33 PM   #6 (permalink)
Deaf Eddie's Avatar
The tone pot is ALWAYS gonna affect both pups when both are on - PERIOD. No way around that.
The correct way to wire what you seem to be after - at least, no tone on the humbucker played solo - would be to run both pups to the toggle, then the volume pot, then the output jack. Connect the tone pot to the toggle on the same lug as the G&L bridge pup.
Wired that way, you get the humbucker solo with no tone. The "both" and bridge solo throws WILL have the tone pot, no way around that.
YMMV - I been wrong before...
Deaf Eddie is offline   Reply With Quote
Old January 21st, 2009, 12:50 PM   #7 (permalink)
Deaf Eddie's Avatar
Old January 21st, 2009, 04:08 PM   #8 (permalink)
Thank you all for replying, especially Eddie for the diagram!
As I rarely use the middle position, affecting both pickups shouldn't be an issue.
Thanks again!
Alex
