Old January 19th, 2009, 07:00 PM   #1 (permalink)
Verne Bunsen's Avatar
No tone pot? Yea? Nay?
I'm trying to make room for some switches on my control plate and am considering wiring it up with no tone pot, just a master volume pot. I always leave the tone pot wide open anyway, I do all my adjustments on an eq. Anyone ever done this? Hows it sound?
Verne Bunsen is offline   Reply With Quote
Old January 19th, 2009, 07:04 PM   #2 (permalink)
Yea. I have mostly always done it on my Teles. One of these days I'm going to treat myself to a custom plate so I'm not looking at a hole every time I pick it up.
It will sound about the same as a "no load," or a bit brighter than with a standard pot dimed.
Chris Leger is offline   Reply With Quote
Old January 19th, 2009, 07:08 PM   #3 (permalink)
JohnnyCrash's Avatar
It's a bit more open, especially on the top end.
I rarely use Tone controls either.
I constantly have to remind myself I'm a grownup and it's just the internet.
Old January 19th, 2009, 07:10 PM   #4 (permalink)
robt57's Avatar
I pulled my tone in one Tele for a vari-tone. The volume tames it, I hardly ever run the vol wide open unless the vari-tone is in a non bypass position,
Leo's Great, Leo's Good, let us thank him for our... Twang!
Old January 19th, 2009, 07:18 PM   #5 (permalink)
Guitfiddler's Avatar
I use my tone knob a lot. I always play with the volume all up, so it's a necessity for me to be able to darken the bridge/brighten the neck. You could bust out the router and put your extra switches under the pickguard.
Guitfiddler is offline   Reply With Quote
Old January 19th, 2009, 07:27 PM   #6 (permalink)
PaperTiger's Avatar
i am interested in this mod too. Ive changed pickups and minor things like that but it might be over my head. Let us know how it goes.
PaperTiger is offline   Reply With Quote
Old January 19th, 2009, 07:35 PM   #7 (permalink)
It's as simple as tearing it out. All you need is something to cut the wires.
A soldering iron would be better, obviously.
Old January 19th, 2009, 07:41 PM   #8 (permalink)
PaperTiger's Avatar
gotcha, thanks for the heads up.
Old January 19th, 2009, 07:48 PM   #9 (permalink)
jefrs's Avatar
If you don't ever use the tone pot, go for it.
Me, I've had guitars with switches all over them, I now prefer one vol, one tone.
jefrs is online now   Reply With Quote
Old January 19th, 2009, 10:20 PM   #10 (permalink)
I've heard that from a number of folks, seems like there's a curve to it, you start screwing with your wiring and it gets weirder and weirder until you start going back the other way and end up relishing the simplicity of 2 pots and a 3 pos switch. Thats alright, I'm up for the ride Thanks for all the input guys, it's been most helpful! I'm heading out of town for a couple weeks, but I think I'll give it a shot when I get back. Worst case, I change it back. I can handle that.
Old January 20th, 2009, 04:59 AM   #11 (permalink)
Rob DiStefano's Avatar
Depends on yer requirements - I prefer making a tone pot no-load and have the best of all worlds. Need to add a switch? Use a push-pull DPDT no-load tone pot.
Old January 20th, 2009, 05:24 AM   #12 (permalink)
Yeah, I've already got both pots as push/pulls. I'm looking to pull the tone pot, add a hole to the control plate and end up with 2 on/on/on switches and the volume pot. What I'm looking for is a way to get series/single/parallel switching for both pups without routing new holes. And, while I never touch the tone pot I do occasionally roll off the volume, so I'd prefer to keep that pot. I've never used a no-load pot, just seen them mentioned around here. Just allows you to run wide open with no treble bleed?
Old January 20th, 2009, 05:37 AM   #13 (permalink)
A no-load pot totally removes the tone pot/cap from the circuit - this has nothing to do with "treble bleed", which is - at its simplest form - just a .001uf cap across the volume pot's input and wiper lugs.
For what you want to do, you need to add an on-on-on mini/micro switch.
FWIW, I don't like using those small push/pull pots for a guitar's volume control - not enuf sweep range to volume attenuation. It matters much less for tone pots, IMO.
Old January 20th, 2009, 05:53 AM   #14 (permalink)
octatonic's Avatar
I go for 1 vol, 1 tone with a momentary kill-switch between them.
I had a tele with EMG's and the midrange booster in place of the tone pot.
Ultimately I found it limiting.
Old January 20th, 2009, 05:55 AM   #15 (permalink)
Thanks for the clarification on that, Rob! And yeah, I have been disappointed with the sweep of this push/pull; if I can get the on/on/ons in there I could do away with it and get back to a "proper" pot, which would be nice.
Old January 20th, 2009, 07:12 AM   #16 (permalink)
GuloGulo's Avatar
I don't use a tone too much but I can't seem to get rid of it. Its the poor mans wah pedal, especially if you wire it right.
GuloGulo is offline   Reply With Quote
Old January 20th, 2009, 09:06 AM   #17 (permalink)
Doug Ferguson's Avatar
+1. I'm getting ready to drop one in my #1. I rarely touch the tone, but occasionally I'll darken it a bit. The no-load will give me an Esquire bridge tone on a tele, but allow me to tweak it if needed. The best of all worlds indeed!
"If I don't like the way the times are moving I shall refuse to accompany them." -Horace Rumpole
Doug Ferguson is offline   Reply With Quote
