tons of vintage info here
http://www.provide.net/~cfh/fender.html#specs in short, the early ones had a single button retainer for the B & e strings next to the A tuner. Just line it up after you string it up. I took one off my tele and works well. They switched to the butterfly style around '56, and in '71 they added a second butterfly. Peghead String Guides (or "String Tree"). String guides were used on most models to give the treble strings greater string tension across the nut. * 1950 to Mid-1956: Single round "button" string guide for E & B strings. * Mid 1956: Changed to a "butterfly" string guide. * 1959: a metal spacer is used beneath the butterfly string guide. * 1964: the metal spacer is changed to a nylon spacer beneath the butterfly string guide during 1964. * 1971: two butterfly clips are used for the E, B, G, & D strings on the Stratocaster, Telecaster, Telecaster Deluxe, Custom Telecaster. * 1976: two butterfly clips on the Mustang. |
yes, by all means don't mount it til after your strings are on — then put it over the strings, placed at the vertical location you want and push down to mark where your screw hole will be.
I remember reading it somewhere that Leo and the gang put next to the A string, must of miss understood. Found something else where it was originally at the D &G strings, like you said. Also didn't add the spacer til 56, looks weird compared to the one with a spacer and lower on the headstock.
