Nice execution. Yeah, cut your own pickguard with an 'S' neck pocket, or have an overhung 22 fret neck like this, and keep right on coming!
I certainly prefer a perfect fit of a T neck to a T pocket, etc. but this could work for a couple months, a couple years and then be sold or put into a Strat build Bubbanov If you keep me on, I'm willing to try much much harder guessing! Promise! |
I'm in the same situation, I've got a 22 fret Strat neck going on a butterscotch body with reliced hardware and I thought I would just cut the headstock into the Tele shape. Nope, not enough wood. It could be done by adding wood, then cutting to shape but you would probably have to paint it.
Strat headstocks look cool on Teles and vice versa, anyhow! I think the heel is the biggest issue though, and putting a strat beck on a project tele at my buddy's repair shop recently meant reshaping the heel dramatically.
Best of luck, though!
Proverbs 3:6 Matthew 5:44 |
I think there's a enough wood on a Strat headstock to cut it into a reasonable facsimile of a Telecaster headstock. You might have to fudge it just a little but I'll bet no one would ever be able to tell.
#9 (permalink) | |
nice overlaying comparison...if i like it with strat head i will leave it like that if not i will cut it. but does a 21 fret neck fit without shaping the pocket? im going pickguard-less by the way. |
#13 (permalink) | |
#19 (permalink) | |
Now, a Tele neck on a Strat body, that's a different story.... |
#20 (permalink) |
I have found that Strat necks sell for less ( on average ) than Tele necks on Ebay ( a lot more Strats out there I guess ). So I made a jig of a Fender Tele headstock and a jig for the neck pocket rout on the pickguard. If it is a 22 fret, I do not have to mess with the neck pocket on the body. If it is 21 fret, I just modify the neck at the heel ( mostly done with a RO sander and finished up by hand with 80 grit then 220 ). It works pretty good and usually only takes about 30 minutes. I made the jigs out of 1/2" MDF.
#21 (permalink) |
I've done at least 6 i can remeber.The vintage strat headstock is very tight but very doable,nobody ever noticed mine.The way to go is get the strat necks with big 70's style peghead, like some of the cheap squier ones.pleanty of wood there to work with.I can remember buying 3 from warmoth years ago all with awesome birdeye and they were very cheap too. As far as the gaps in the neck pocket,get the neck in straight,tighten it down and find something else to worry about.I've also put tele necks on strats when that's all i had,about 10 mins. with a file is all you need.
