Fret leveling
I see that in most fret leveling tutorials, the levelers used are usually flat on the bottom. What I dont understand is does'nt that mess up the fret radius? If you have a 7 1/4 radius on your neck, by the time your done wont the frets be really thin in the middle? Would'nt it be better to use a leveler that has radius that matches the neck? A little confused
You gotta move your leveler from side to side across the neck and sand evenly. It's not the hardest thing in the world to do, which I know because even I manage to do it. I use the narrow side of one of StewMac's bars.
my blog: eryque.blogspot.com Updated 9.17.08! Subscribe_____________________
I have a light set up directly over my workbench, so I don't even need the sharpie. It's easy enough to see where the frets have been sanded.
Just pop the neck off, adjust the trussrod until the neck is dead straight, pop the nut out and take it out the back to the concrete patio.
Rub it up and down on the flat concrete until all the frets are mashed up and flat - then crown them with a crowning file. Funny thing is - I know someone who did this ... and it actually worked. I do not recommend it.
#7 (permalink) | |
Creator of Fine Sawdust and Expensive Kindling. |
Nick, you promised you'd never tell any one.
http://www.myspace.com/otiskeithwatkins |
VENDOR
Thank you...here are some Finished Pics
#14 (permalink) |
But seriously... back on topic, exactly how important is it to have your fret leveling device "perfectly" flat... how flat is flat enough? Are the StewMac and other levelers that are measured to 0.000000000001 of an inch worth the money, or can you have success with a home-made device?
#17 (permalink) |
Here is my cheap and effective fret leverer. Aluminum angle iron which is straight as string and stable. I cut it to four, six and twelve inch lengths. Two different grades of paper can be glued to each side (spray glue the paper not the aluminum). If you start with fine grade paper you will get a shined surface telling you where there are issues.
Buildin' and Playin' |
#18 (permalink) | ||
