Brushed-on Nitro Finish?
Whereas I don't have the means to facilitate sprayed-on nitro, would it be possible to finish a guitar just by brushing thin coats and sanding?
Would the fumes be just as dangerous? |
| Sponsored Links |
Brushing nitro just doesnt work IMHO .the paint was designed for spraying in most cases. Brushing it on is tricky as the the brush marks dont roll out as the paint dries very quickly and also the next coat may well lift the lower coat ,as the thinners in the coat you are applying will dissolve the coat already on .
Well .............. Deft makes a brushing lacquer. I suggest you buy a small can along with some lacquer thinner do a little experimenting using some 2x4 pieces.
Jack's Disclaimer: When I say something.... always ask yourself ..... "What the hell does he know?" _ ![]() Guys - learn to disable the flash on your digital cameras. |
#7 (permalink) | |
Do you have an outside area where you could set up a temporary booth. Cardboard or shower curtain could be used to cut out any breeze or dust? Just a thought. I do mine in the same shed where i do the woodwork. I just let everything settle for a while before spraying then stay out til the lacquar dissipates. |
