Old July 17th, 2008, 03:40 AM   #1 (permalink)
low E too bassy on 52 tele ri
hey fellas
my low E is too bassy. only occurs in bridge position. my bridge pu is a duncan vintage stack (stk-t3b). believe me, i've tried everything to avoid the issue except anything invasive. does anyone have this tele and this pu and experience the same issue? any advice in general?
-kris
krp312 is offline   Reply With Quote
Old July 17th, 2008, 11:47 AM   #2 (permalink)
Did you try messing around with pickup height? Lower the bass side a little
acfnqiowuva is offline   Reply With Quote
Old July 17th, 2008, 12:18 PM   #3 (permalink)
boris bubbanov's Avatar
I had one in my 69 MIM Thinline and pulled it out.
What kind of bridge and saddles are you using? I noticed that this alder bodied Tele with the aluminum E-A saddle from Dale Clark does de-emphasize the E and A and lets you crank up the amp on the other 4 strings, although this has a set of Keystones.
Here are some guys that know a bit about the pickup you have:
http://www.tdpri.com/forum/tele-tech...=1#post1097276
Bubban0v
Old July 17th, 2008, 05:21 PM   #4 (permalink)
yeah, definitely. unfortunately this is the kicker because when trying to do so, the pu runs into the cavity of the guitar and refuses to go any further down. i do believe that a simply bass side lowering would fix everything!
the vintage 52 ashtray style bridge, with fender's 6-piece saddle replacement that comes with the guitar when you buy it. (i got rid of the traditional 3 piece saddles.)
unfortunately i know it's not the bridge/saddles because simply switching to the mid position gives a much more balanced response across the strings
Old July 17th, 2008, 06:40 PM   #5 (permalink)
mellecaster's Avatar
Well, I reckon you're going to have to deepen the Pickup cavity.
I have never owned an Ipod or Blackberry..and doubt that I ever will......
