Old July 14th, 2008, 08:30 PM   #1 (permalink)
robt57's Avatar
OK, What bit to route F-hole??
Will get there tomorrow on these 2 thinline bodies...
Me tinks I am short a small radius bit for the task, with a bearing I mean..
Leo's Great, Leo's Good, let us thank him for our... Twang!
Old July 14th, 2008, 08:43 PM   #2 (permalink)
jwells393's Avatar
I don't think any such bearing bit exists. A 1/4 in straight bit can be used. Pre-drill to remove much of the wood, and adjust the depth of the 1/4 in. bit so the shaft of the bit rides on the template. Essentially the bit shaft acts as a bearing.
Old July 14th, 2008, 09:20 PM   #3 (permalink)
On the couple of thinlines I've made, I've used the smaller dia stewmac bit( 3/8) and then filed out the area that it can't get into. That worked pretty well.
Marty
Old July 14th, 2008, 10:50 PM   #4 (permalink)
e-merlin's Avatar
I think the proper bit would be a scroll saw. Assuming you haven't glued the top on yet!
'tone is in the underpants'
Old July 14th, 2008, 10:52 PM   #5 (permalink)
robt57's Avatar
Better cut it before I glue the top on, eh? ;)
Old July 15th, 2008, 04:36 AM   #6 (permalink)
jwells393's Avatar
A scroll saw would be good to rough cut the F-hole but you need to rout it for a good look. Here's the bit I mentioned above.
Old July 15th, 2008, 05:07 AM   #7 (permalink)
Nick JD's Avatar
This one has a drill tip for easy starting. 3/4" cutting length, 1/4" diameter flute and shaft (shaft used as pilot). Freud 26-100. Ten bucks.
Old July 15th, 2008, 08:53 AM   #8 (permalink)
martyb1's Avatar
I have used these,just like Jack,but on the last two I did I used a 1/4 flush trim bit
Mounted in the router table with the template on top for the bearing to run on.The bearing just fits through the narrowest part.
I used a 1/4" thick template
And cut it out before I glue the top on.I do also use a drill to remove the majority of the material first
Before throwing it out,make sure it's not 16x13x1.75
martyb1 is offline   Reply With Quote
Old July 15th, 2008, 09:35 AM   #9 (permalink)
Ironwolf's Avatar
I used the 1/4" straight, same as Jwells. Routed after the top was mounted, got everything clean, just had to go around the edges with an emory board.
Oderint Dum Metuant - Nero Caesar
Ironwolf is offline   Reply With Quote
Old July 15th, 2008, 10:34 AM   #10 (permalink)
jwells393's Avatar
Hmmm ........ So that's what it looks like Marty.
Old July 15th, 2008, 12:29 PM   #11 (permalink)
robt57's Avatar
Well thank for all the input folks. I decided in fact to cot them pprior to gluing. Just one extra stop gap in case. Easier to make another top than to toss a whole body. ;) Or should I say repair and make a painted one? ;)
Ron suggested in a PM to use, well... here's a paste from the message:
"use a 1/4 spiral bit. I chuck it so there's about 1/2 inch of the shank to ride on the template, allowing the cutting edge to shape the hole."
Ciao, Robt
Old July 15th, 2008, 07:10 PM   #12 (permalink)
Hmmmm...Do I smell melted plastic? LOL.
Marty
Old July 16th, 2008, 12:25 AM   #13 (permalink)
e-merlin's Avatar
Cool! Glad I tuned into this thread. Lots of good info.
Old July 16th, 2008, 07:02 PM   #14 (permalink)
old_picker's Avatar
1/4" straight flute is what i use
start of shaft rests on the template
cut out what you can with brad points b4 you start
piece of cake
do it after the top is glued no worries
ray
old_picker is offline   Reply With Quote
