Old July 13th, 2008, 11:03 PM   #1 (permalink)
RiverDog's Avatar
1st two strings feel/sound dead
Can anyone help me with this? One of my teles has a problem where the 1st and 2nd strings feel "dead". When I pick them while fretting a note it just kinda sounds like plink. There's no string buzz so I don't think it's just string height or neck bow. Any idea what might be the culprit? Thanks!
Aaron
"Rain is God's way of washing off hippies." - Demetri Martin
RiverDog is offline   Reply With Quote
Old July 14th, 2008, 11:13 AM   #2 (permalink)
mellecaster's Avatar
Thru an Amp....or dare I say Unplugged ?
I have never owned an Ipod or Blackberry..and doubt that I ever will......
Old July 14th, 2008, 01:30 PM   #3 (permalink)
Sounds like the string is hitting a pickup, higher fret, or maybe the saddle has a problem. --Rob
robrohdeszudy is offline   Reply With Quote
Old July 14th, 2008, 04:02 PM   #4 (permalink)
neck relief?,falling saddles what style bridge.
sometimes on brand new guitarsthe heighth adj screws will vibrate causing the saddles to fall and the strings to get plinky. if this is the problem, a drop of clear nail polish or removable loctite will secure them.
if this is an Affinity tele with top loading bridge, conversion to thru body style will cure this by apllying added string pressure to the saddles and the biproduct is just better tone and sustain(and cutting about 30 minutes from your restringing process.
hockey_head is offline   Reply With Quote
Old July 14th, 2008, 06:28 PM   #5 (permalink)
RiverDog's Avatar
Sorry, more info:
It's a partscaster with a 6 saddle bridge like a MIM Tele has. It's definitely not hitting the pickups and yes, it does it unplugged.
I'll take a look at the saddle.
Aaron
Old July 14th, 2008, 06:37 PM   #6 (permalink)
Ethical's Avatar
Failing nut perhaps?
Ted
If it wasn't for bad luck, I'd have no luck at all
Ethical is offline   Reply With Quote
Old July 14th, 2008, 10:57 PM   #7 (permalink)
Moderator
Tim Armstrong's Avatar
Could be defective strings (been there!). Have you tried a replacing them?
Cheers, Tim
http://www.moodswingers.org
Tim Armstrong is online now   Reply With Quote
Old July 15th, 2008, 04:47 PM   #8 (permalink)
blue metalflake's Avatar
Try changing the strings first, then look at the nut.
blue metalflake is offline   Reply With Quote
Old July 15th, 2008, 05:26 PM   #9 (permalink)
garytelecastor's Avatar
check your nut; check your pup height
éí 'aaníígÓÓ 'áhoot'é
Would you mind holding this bag while we go through the custom shop?????
Redd Volkaert is a Jedi Knight at one with the Force!!!
garytelecastor is offline   Reply With Quote
Old July 15th, 2008, 06:12 PM   #10 (permalink)
RiverDog's Avatar
I did change the strings. What should I look for on the nut? Slots too tight?
(Thanks for the replies!)
Aaron
Old July 15th, 2008, 07:46 PM   #11 (permalink)
old_picker's Avatar
bad angle in the nut slots
just angle them down a little at a time towards the tuners
till you get a nice clear tone
you got to try for the same or a little less angle than the string break
you will need some nut files
the string is vibrating on the front or rear of the nut
once you get that cut at the right angle you will have a nice clear tone
takes a few minutes but go little by little
ray
old_picker is offline   Reply With Quote
Old July 15th, 2008, 10:25 PM   #12 (permalink)
AnArmyOfJuan's Avatar
but he said it sounds dead when fretting... wouldn't that take the nut out of the equation?
Pat V. and the Detroit 3
AnArmyOfJuan is offline   Reply With Quote
Old July 15th, 2008, 10:48 PM   #13 (permalink)
RiverDog's Avatar
Exactly. When I play the strings open you don't really hear a problem but when I fret that's when there's not much sound.
Aaron
Old July 16th, 2008, 07:44 PM   #14 (permalink)
old_picker's Avatar
sorry yes you are right
never read the post proper did i?
sounds like a dead fret?
which frets sound dead ? or is it dead on all frets
you need to go up the board and see if you can locate the probklem area
does it stop plinking after a particlur fret?
is there a high fret somewhere?? a fret not seated properly?
also check your saddle screws - are both seated firnly on the bridge plate?
if its a 3 barrel bridge its may be there - maybe that barrell has a void inside and replacing it may solve the problem
lets know what you find
ray
