Old July 13th, 2008, 04:19 PM   #1 (permalink)
Stenciling a neck
I have an old guitar neck, and I want to mod it and put my own logo on it, just for fun. How do I go about doing this?
Intervenient is offline   Reply With Quote
Old July 13th, 2008, 04:35 PM   #2 (permalink)
sean79's Avatar
Water-slide decal. Make (or put) the design on your computer, print it on the decal "paper," apply it, and seal it.
Every now and then I know it's kind of hard to tell, but I'm still alive and well.
sean79 is offline   Reply With Quote
Old July 13th, 2008, 04:36 PM   #3 (permalink)
Big Mike Simpson's Avatar
Search under "decal" and you will find lots of info... I made mine using a kit that is sold by Testors and is available in hobby shops that sell stuff for RC cars and airplanes.
Big Mike Simpson is online now   Reply With Quote
Old July 13th, 2008, 05:03 PM   #4 (permalink)
How do I remove the old logo?
Old July 13th, 2008, 06:08 PM   #5 (permalink)
sean79's Avatar
That's going to depend on whether it's under a clear coat or not and how it was applied. If it's over the top coat, you may have a shot with some kind of solvent - but you could run the risk of eating your clear coat. You might also have luck with real fine sandpaper and/or 0000 steel wool. If it's under the clear coat, you'll have to remove the finish along with the logo - sanding or chemical stripping. What kind of neck are we talking about?
Old July 13th, 2008, 11:28 PM   #6 (permalink)
I've no idea, honestly. It seems like a MIM Telecaster neck. I'm trying to concert the headstock to look like This. I don't mind the color so much, black would be fine if it's easier, but I'm having a hard time finding the exact logo.
Old July 14th, 2008, 01:16 AM   #7 (permalink)
Is this it?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXESK4
Old July 14th, 2008, 01:18 AM   #8 (permalink)
nicktele5150's Avatar
i did somethin completly different on an fender starcaster neck i wood burnt my last name in cursive on the front and made a serial number on the back
nothin beats a good tele
nicktele5150 is offline   Reply With Quote
Old July 15th, 2008, 02:25 PM   #9 (permalink)
I've decided to go the route of water-slide. Is it relatively easy?
Old July 15th, 2008, 03:16 PM   #10 (permalink)
jwells393's Avatar
There are two types of water slide decal paper. One for inkjet printers and one for laser printers. Don't run inkjet paper through a laser printer. If you're printing on an inkjet printer you'll need to spray something on the decal before applying it. Something like Krylon Acrylic Clear or clear lacquer. Otherwise the ink will smear when you apply it. Not a problem when going the laser printer route.
When spraying lacquer over in inkjet decal you should do several light mist coats rather than wet coats until you get some lacquer build-up.
Old July 15th, 2008, 04:17 PM   #11 (permalink)
can you buy water slide decal paper at wal mart?
Old July 15th, 2008, 04:18 PM   #12 (permalink)
i should have done a water slide like that my last name is simpson too
Old July 15th, 2008, 06:05 PM   #13 (permalink)
sean79's Avatar
...but I'm having a hard time finding the exact logo.
I can't tell from the picture you posted (the one you said you wanted yours to look like) - are you wanting to put a Fender logo on it, or do you want to do a truly custom logo design?
Old July 18th, 2008, 01:52 PM   #14 (permalink)
Both. I want the logo I posted on the front of the head stock, and then a custom one on the back.
