Old July 6th, 2008, 10:54 AM   #1 (permalink)
Adding weight to a Thinline
Boys, I need to add some weight to a Thinline copy, very neck heavy. I really like the guitar and I am working on doing a 72 Thinline build with WRHB in it but I need some weight in that body for counterbalalnce, any suggestions?
okies is offline   Reply With Quote
Old July 6th, 2008, 11:21 AM   #2 (permalink)
jwells393's Avatar
Get yourself a wide strap.
Old July 6th, 2008, 12:12 PM   #3 (permalink)
If it doesn't have them already, replace the pegs with kluson style tuners. That should remove some dead weight.
crowden is offline   Reply With Quote
Old July 6th, 2008, 12:21 PM   #4 (permalink)
Frontier9's Avatar
Yup. Wide strap + suede = problem solved
Frontier9 is offline   Reply With Quote
Old July 6th, 2008, 12:31 PM   #5 (permalink)
bug music's Avatar
Hmm... Someone say Bigsby ?
- Jay
"When I die they're gonna say He couldn't play sh*t, but he sure made it sound good" - Hound Dog Taylor
bug music is online now   Reply With Quote
Old July 6th, 2008, 12:42 PM   #6 (permalink)
woodman's Avatar
once, long ago and far away in a state of stupidity, i filled the F-hole cavity of a Thinline with polyester resin (the kind they build boats with). it was never neck-heavy again. however, it was heavy for all time! i doubt if this would be your choice of solutions.
BAND PAGES:
Old July 6th, 2008, 12:50 PM   #7 (permalink)
jwells393's Avatar
Hmmm.......... I've converted a solid body guitar to a semi-hollow but going the other way ............. that's different.
Old July 6th, 2008, 03:19 PM   #8 (permalink)
boris bubbanov's Avatar
I'll bet Bill K. did not know that, when he invited you to share the stage with him the other night!
Shhhh.. about things like this. People are listening!
+1 on the Gotoh "klusons", and if that ain't enough, the wide suede strap, okies.
Bubban0v
Old July 6th, 2008, 03:42 PM   #9 (permalink)
Tdot's Avatar
Maybe I'm oversimplifying, but you could just hang my wife's 3 pound key chain on the bottom strap button.
Old July 6th, 2008, 03:46 PM   #10 (permalink)
Actually, I do use a pretty wide strap, not enough help tho. I was actually thinking along the lines of Woodmans idea, just not sure what kind of filler to use. Would need to be carefull and not use to much filler. I need about a pound of weight. The guitar (Xaviere Tele) would still be well under 8 pounds.
I routed the pickup holes out to fit the big Wide Range humbuckers and wound up having to route into the body cavity to get big enough. I wired it up yesterday just to do a tone check and wow, great heavenly Albert Collins, but very microphonic, even with moderate distortion. I figure there is too much empty space in the body now for sure and a little filler might just back the feedback off enough to make this one a real keeper.
Old July 6th, 2008, 03:46 PM   #11 (permalink)
Moderator
Tim Armstrong's Avatar
Howsabout a nice little mojo bag full of lead shot, hanging off your strap button. That way, if a bar fight breaks out, you have another weapon!
Cheers, Tim
http://www.moodswingers.org
Tim Armstrong is online now   Reply With Quote
Old July 6th, 2008, 04:15 PM   #12 (permalink)
TELE_BLUES's Avatar
I'm going with the wide strap idea as the best solution.I have a nice wide one for my 8 string bass.Adding weight to the guitar is probably not a good idea.although i saw one guy he got a longer screw for the rear stap button and aded a bunch of large washers as i remeber he was using one of those skinny 50's style straps.It kinda looked like he had one of those short cans of beer on there.There is some merit to TIM'S idea you could use it as a blackjack if a fightbreaks out.Pleasee check local laws reguarding the use of the devices.lol
TELE_BLUES is offline   Reply With Quote
Old July 6th, 2008, 07:11 PM   #13 (permalink)
I don't know if they still make them (I'm not a roofer) but roofers use something called lead "boots" to go around the plumbing pipes that stick up through the roof (you can't have a vacuum without a vent). They're made up of about 1/8" or thinner lead sheeting and you can cut them up pretty easily with a pair of heavy scissors. By lining the bottom of your pickup and control cavities with it, it should add the weight you need.
You could try it out first by just using some rubber cement to hold it in and then use a more permanent method later. The advantage to this idea is that is reversible where as the resin would not be.
You can probably still get the boots at a roofing supply store but... lead, along with all metals, have gone way up in price so don't be shocked to much at the price...
Old July 6th, 2008, 08:28 PM   #14 (permalink)
woodman's Avatar
now there's an idea! back in the day, i played many bars where having a blackjack at the standing ready would have created a more warm, secure feeling.
BAND PAGES:
Old July 7th, 2008, 02:11 AM   #15 (permalink)
Hey, never thought about the roofing boots, great idea, I'll check it out, reversible is good. Thanks for the help everyone.
Old July 7th, 2008, 03:53 AM   #16 (permalink)
sean79's Avatar
Hang a pair of these from the back strap button. I think they come in other colors.
(thanks to e-merlin for posting this picture on another thread)
Every now and then I know it's kind of hard to tell, but I'm still alive and well.
sean79 is offline   Reply With Quote
Old July 7th, 2008, 04:36 AM   #17 (permalink)
boneyguy's Avatar
"Shut up n' play yer guitar"
boneyguy is offline   Reply With Quote
Old July 7th, 2008, 06:50 AM   #18 (permalink)
pengipete's Avatar
You could train a canary to perch on the headstock and flap it's wings really hard or you could tie a piece of string around your leg and fasten it to the strap button.
pengipete is offline   Reply With Quote
Old July 7th, 2008, 09:25 AM   #19 (permalink)
Weight
Or you could put a stacked bridge pick up in?
Gary
Gary in Boston is offline   Reply With Quote
Old July 7th, 2008, 10:04 AM   #20 (permalink)
jwells393's Avatar
Simple solution: Sell the guitar and get yourself a heavy solid-body.
I really don't see how a light weight Thinline with a wide suede strap is going to be neck heavy.
Another solution: Apply velcro to your strap and the shoulder of your shirt.
Another solution: Get some of this non-slip SUPERPAD II® and glue it to your strap.
Old July 7th, 2008, 10:37 AM   #21 (permalink)
sean79's Avatar
Is "neck heaviness" a common problem with Thinlines? Does okies' have an exceptionally light body, or an exceptionally heavy headstock end? I don't think I've ever played one.
Old July 17th, 2008, 01:04 PM   #22 (permalink)
andrewb's Avatar
simple....
take your pickgaurd off.. and put a weight in the space behind your controls....sand bag or something.....
no one would ever know.. and it is not noticable.... easilly removed....
andrewb is offline   Reply With Quote
