go here: Esquire wiring
follow directions for the last diagram... I believe that's the one. I use Sprague orange drop .047 caps with pretty good results... you can get those on ebay. Anyone validate?
~Cole Cole's website Cole's MySpace "The only currency we have is influential communication." |
#4 (permalink) | |
No, for the cocked wah sound you need to replace the .050 cap that goes from from the volume pot to the switch to a .010 or something similar. I use a .010. and .05 caps and .047 caps are virtually the same thing. I had a site that I got a whole bunch of caps off of for cheap. I'll see if I can find it again.
"The only true currency in this bankrupt world, is what you share with someone else when you're uncool." -Lester Bangs |
okay here's where I got my caps. Just make sure to watch your zeros. They have a lot of different values. So for this esquire you will want a .047 and a .01.
Linkage for Caps
#6 (permalink) | |
"You released the ******* fury!" |
Just put in an order in for some stuff i wanted on specialist guitars, and i threw in a couple of .47's, and by chance put in a couple of .01's aswell! woot!!
so what one needs to be the 47 and which one of the 01? cheers for the help guys. |
#8 (permalink) | |
#9 (permalink) | |
how do you set the wiring? just the same? |
Exactly. Don't go by the stagger. Just follow the diagram with the sides of the switch and ignore the stagger. It won't look as pretty as the diagram.
#11 (permalink) | |
They're cheap and do the job. I tried the 0,1 uf some while ago but I've stuck with the 0,47 (by the way, 0,50 was the old value, 0,47's are exactly the same) ;)
When I think of all the good times that I've wasted, having good times |
#12 (permalink) | |
IMO the .0033uf cap is still bright enough to be almost neck or neck/bridge type color (excellent for crunchy arpegios & chords), while the .010uf is better suited to lead stuff, both will do the cocked wah lead thing.
"The beast in me is caged by frail & fragile bar" Johnny Cash |
