Old June 11th, 2008, 03:58 PM   #1 (permalink)
How can I do this? (HSS Pots/Capacitor)
Hey all!
I am building a three pickup tele. Humbucker in the neck, and single coils in the middle and bridge. I know I should use 500k pots for the humbucker and 250k for the single coils, but how can I do this?
I've looked at the wiring for the Fat Tele and see that they use a resistor, but that is for a two pickup tele. Do I add another resistor for the middle pickup? And how do I use different value capacitors for the Humbucker and the single coils.
Any advice would be appreciated! Thanks!
Chumpito
Chumpito
wanna-be guitarist
Chumpito is offline   Reply With Quote
Old June 11th, 2008, 05:48 PM   #2 (permalink)
Lance's Avatar
I just finished a HSS Strat (fat strat) Warmoth project. I opted for 500K pots. The cap I'm currently using is .22mfd. The 500K pot keeps the humbucker sounding good but I do back off on the tone for two singles.
You can find a good diagram on the Seymour Duncan site.
like this: http://www.seymourduncan.com/support...2s_1v_1t_5w_as
But, I'd use 500K pots and a 5 way switch.
Lance
Old June 11th, 2008, 07:22 PM   #3 (permalink)
e-merlin's Avatar
Yeah, just go with 500K pots. That's what everyone does. And if it's too bright on the singles, roll down the tone knob a bit.
'tone is in the underpants'
Old June 11th, 2008, 11:41 PM   #4 (permalink)
w0odman's Avatar
Could go with 250 k pots but not run the neck humbucker through the tone pot. When are you really going to back tone off of a neck humbucker? Plus it will brighten up the neck bucker a little. worth a try.
To do this the wire that runs from the tone pot lug to the volume pot lug needs to be changed to run from the tone pot lug to the bridge pup lead lug on the switch.
"The only true currency in this bankrupt world, is what you share with someone else when you're uncool."
-Lester Bangs
w0odman is offline   Reply With Quote
