Fender 250k No Load Pot
Hey all,
Is anyone out there using the Fender 250k No Load Pot. How are you using it and what has been your experience? Thanks! Chumpito
Chumpito wanna-be guitarist |
| Sponsored Links |
I have them in two of my Teles. I don't know about everyone else, but I use it to 'push' my leads through the mix a little when need be. Keep in mind, I use them mostly with country/sounthern rock gigs where the tone is set pretty twangy to begin with and this just gives me a little bit more.
They are also in the Current production of the Fender Stratocaster. I don't really like them at all and would prefer a regular 250K Audio Pot.
Just my opinion
tazzboy Guitar: 1982 Gibson Les Paul Standard AMP: 59 Bassman Reissue. EFFECTS: 2 Boss TR-2 Tremolo, Boss CE-2 Chorus, and Boss DM-3 Echo Delay. |
I tried one for my Esquire but went with a direct lead wiring instead. You can make a no-load in about 5 minutes and try one out:
http://www.projectguitar.com/tut/pots.htm |
I love the fender no load pots for tone controls in teles - I really like the "click" to know it's engaged. I use mine alot for a couple applications - one it's a great way to brighten up the front tele pickups tone and get some snap. Two, I like to engage it and turn my volume control down to get a "stock pickup" sound. I say that because my Don Mare set - 0038 and stelly - has some girth to it, especially the 0038. By turning the volume down a little bit and engaging the no load feature, I can pretty well simulate a stock set of underwound tele pickups. It really adds versatility to my rig. So I'm a big fan of them.
I think they really shine with hotter or darker pickups. I added one to my Nashville Tele and it really brings out the twang in those Tex Mex pickups.
Life is better when you just make it up as you go along. |
I posted this separately and got no nibbles - does anyone know of a source for miniature/small no-load pots?
I have three knobs on my Tele control plate so the tone control needs to be a small pot in order for it to fit (next to a Fishman Powerchip). I usually back the tone control back a little for the tele bridge pickup, but the humbucker in the neck I like to leave wide open and it's still a little dark - a noload tone should do the trick, no?
#14 (permalink) | |
As for your question there, about the 'darkness,' maybe you could use a different value capacitor in the tone circuit, or a higher value (in ohms) volume pot. This would shape your total tone, in either case, so you might want to look at experimenting. I just installed a 250k No-loader, Fender or CTS pot, in the Tone pos (figured that it was the only way to do it since there was not a full resistance value on the 2 outside terminals, as the volume pot should have). I can tell a difference between the 'notched,' off, position, but when I turn the knob back the other way to engage the circuitry, there is a very annoying Scratch. These pots have a spring putting tension on the shaft of the pot, and any time I pull up on it (when I take it off the notch) there is this awful noise. Is this normal? |
No load? Bypass.
I use a CS Nocaster bridge pup and SD Seth Lover neck pup in my red partcaster . Only the bridge pup is connected to the tone control. The neck 'bucker is completely by-passed. I don't think I would want to lose any treble from the Lover, but sometimes I like to roll back the bridge pup.
What, me worry? |
#16 (permalink) |
I like the added punch I get from the no-load pots. You can get 250K and 500K versions (Fender brand) from Antique Electronics Supply both with solid and split shafts. I've put them in Teles, Jazzmasters, and Jaguars. I also use them as a blender pot in my Strats.
#17 (permalink) |
love them, and use them in all of my tele's
although i will say, a couple of them i have bought havent had much of a click, if any click at all, whereas others i have tried give a real hard click. i prefer the hard click so try to get those ones. |
