Scale length project question - help!
Hi, I've just bought an acepro t-style body off ebay with a yamaha erg121 neck ftted, but not received it yet. the original scale length of the acepro is apparently 24.75 (which i'm used to on my gibson) but the yamaha neck is 25.5. the seller said he's had this neck fitted for some time with no problems and has used it for gigs etc.
I intended to replace the neck with a nice maple/maple fretboard tele style one to complete the look of the guitar, but was wondering if any old tele neck would do - the yamaha neck has been free of problems apparently, but what should i do? is it worth getting a tele neck to replace it with or will i be dogged with problems? Thanks! |
Unless you really really really know what you're doing, count on problems. Positioning the neck so that the distance from the bridge center point to the 12th fret matches the distance from the nut to the 12th fret (12.725 inches), is a lot easier than it sounds.
Be careful! Ward |
#3 (permalink) | |
If there's nothing wrong with the Yahama neck why replace it?
The nut to 12th fret distance on a 25.5 in. scale neck is 12.75 in. |
#8 (permalink) | |
Typically 12th fret to end of heel on a Fender neck is ~ 5 11/16 in. It could vary a little with aftermarket necks .......... but probably not much.
So measure neck pocket to D & G saddles .......add 5 11/16 ......... compare that to nut to 12th fret measurement (12 3/4 in). If it differs a little, is that difference within the saddle adjustment range. If I recall correctly TDPRI member Crowden put a 25.5 scale neck on a Squier Vintage Modified Thinline which had a 24.75 scale neck originally with no problems. |
