stripped adjustment hole on pickup.. help?
so im putting together this guitar and I dont want to mention the pickup maker at this point, but they are hand made, expensive, you get the point...
anyway, after fighting with the neck pickup to fit it in the cavity, i go to screw it into the pickguard and one of the holes through the plastic baseplate is completely stripped. the screw just slides freely in and out. any ideas as to how i might fix this? i need to not only secure the pickup to the pickguard, but it also must be height adjustable (as it it is supposed to be), so i cant just fix it with a nut on the bottom. |
I've fixed this before by putting a nut on the bottom.
Usually have to string it all up, measure how much to raise and lower and then loosen the strings, pull the pickup out and adjust. There is probably a better way to do it.
“Music is perpetual, and only the hearing is intermittent.” - Henry David Thoreau. |
Here's a few ideas...
* Re-tap with a slightly bigger screw * Crazy glue a nut to the pickup * Mount the pickup to the body Cheers and HTH, Bob
Help I've fallen and can't reach my Tele! |
Take some teflon tape (the stuff that you use to install a shower head) and wrap it around the screw before you thread it in.
Life is better when you just make it up as you go along. |
