Old May 15th, 2008, 01:46 PM   #1 (permalink)
Help finding a tele headstock template.
I've done a search. Can't find what I'm looking for.
Does anyone have a template source?
Thanks all.
redddog is offline   Reply With Quote
Old May 15th, 2008, 02:36 PM   #2 (permalink)
Injun Joe's Avatar
I'm working on making whole neck template... How soon do you need one?
Injun Joe is offline   Reply With Quote
Old May 15th, 2008, 02:41 PM   #3 (permalink)
newtwanger's Avatar
Which generation are you looking for and how accurate does it have to be?
early 50s (smaller) are different from the reissues of the early 50s and modern standard are different again (only slightly, the size and the end "nub").
If you specify exactly what you want I bet someone can trace out theirs for you. (I can't as I'm sure you don't want a 72 Tele Deluxe headstock and I have no idea how close my Musikraft headstock is to the real deal.
_________________
newtwanger is offline   Reply With Quote
Old May 15th, 2008, 09:49 PM   #4 (permalink)
How about a 60s headstock?
Old May 15th, 2008, 11:38 PM   #5 (permalink)
jwells393's Avatar
If you're just after the shape and tuner hole centers maybe this will work. Print it 7 in. high maintaining the aspect ratio.
Old May 17th, 2008, 11:34 PM   #6 (permalink)
Thanks Jack. I'll try this one. Basically what I was looking for was a template to get the angle of the straight edge adjacent to the tuners, and the hole spacing, so the strings run in a straight line from the nut to the tuner posts.
I'm making a new neck template nad thought I'd incorporate all the "correct" dimensions all in one piece. I'm less concerned with the actual headstock shape.
vB code is On
Forums Directory
