Old May 15th, 2008, 01:43 PM   #1 (permalink)
surfoverb's Avatar
How to make a no-load pot 'click'
I made a no-load CTS pot but I want it to click, how is it done?
Old May 15th, 2008, 10:31 PM   #2 (permalink)
I'm not exactly sure this is how the Fender no-loads are made, but from what I can tell from mine (just by the way it feels), it has a spring that is constantly pushing down on the wiper inside; then when it gets to the "click" part, it has some sort of indention that it kind of falls into. It doesn't really make a pronounced "click" per se.
Onyx Z is offline   Reply With Quote
Old May 15th, 2008, 10:34 PM   #3 (permalink)
mellecaster's Avatar
Seems like for about $7.95 it would be a lot easier just to buy one that has the detent at the 10 position ?
Old May 16th, 2008, 10:39 AM   #4 (permalink)
surfoverb's Avatar
I'm just trying one on for size so to speak...Since modding an existing pot was really easy and free I figured maybe making it click would be something that also only takes a few minutes.
Old May 16th, 2008, 10:43 AM   #5 (permalink)
rocksteady Max's Avatar
The feel I get from the no-load pot is that there is some kind of magnet ... but impressions can be deceiving
rocksteady Max is offline   Reply With Quote
Old May 16th, 2008, 10:43 AM   #6 (permalink)
w0odman's Avatar
The one that I bought didn't click. I don't think they're supposed to.
"The only true currency in this bankrupt world, is what you share with someone else when you're uncool."
-Lester Bangs
w0odman is offline   Reply With Quote
Old May 16th, 2008, 11:12 AM   #7 (permalink)
no they don't click per se but you feel a resistance when you roll off the pot.
Old May 16th, 2008, 11:27 AM   #8 (permalink)
surfoverb's Avatar
I figured some actually do 'click' into position because I've read about some people not liking that click and preferring a smooth transition. Maybe 'click' isn't the right word, I just mean when you roll the knob to '9' there is a 'wall' so-to-speak and to get it to '10' it takes a little more pressure, that is, there is resistance.
I guess I'll just buy one and take it apart.
Old May 16th, 2008, 12:12 PM   #9 (permalink)
kylef's Avatar
all mines are the same, and ive had solid and split shafts.
as said, like a sring holidng it up, then falls into place on 10...just a smaller pressure needed to roll it in.
kylef is offline   Reply With Quote
Old May 16th, 2008, 03:37 PM   #10 (permalink)
Usually, a pot that is described as "no-load" has that detente (it "clicks"), but if it is described as a "blender", it doesn't click. That is the only difference. If you were to go to acmeguitarworks.com, you'd see both blender and no-load pots. The no-load pots have the detente.
Jim.Collins is offline   Reply With Quote
Old May 16th, 2008, 04:05 PM   #11 (permalink)
surfoverb's Avatar
I thought a blender was just a pot wired to blend in the bridge and neck PUP ala Nocaster?
Regardless what I'm trying to do is get my Esquire wired so that when I'm in the bridge only position I bypass the volume pot as well as the tone but the way the switch is wired the 2 common lugs are bridge and volume.
Old May 16th, 2008, 04:42 PM   #12 (permalink)
That Sir would be Correct...at least that is what I was told, by guys smarter than me......
Old May 24th, 2008, 07:32 AM   #13 (permalink)
idoru's Avatar
To make a detent (as extrapolated from a soldering error by myself): take off the pot casing and make an indent with a hole punch where you want the detent to be. This will require hooking up a multimeter to find where in the travel of the pot the required value is, and finding the equivalent place on the pot casing.
Now, a 40 watt soldering iron will melt the plastic mechanism inside the pot if you hold it in place too long (heh), so all you need to do is use the multimeter to find your place again and heat the indent for long enough. Voila, a detent - one of my old pots now has 3!
Needless to say, practicing on old Squier pots is highly recommended before you attack anything of quality.
c-
idoru is offline   Reply With Quote
vB code is On
Forums Directory
