Old May 14th, 2008, 11:33 AM   #1 (permalink)
help with filling a small hole on headstock
I used the Google search even and am not sure I found the best solution to my problem, which really isn't a problem, but since I'll have the tuners off for some tinkering anyway ...
I replaced the roller string tree on my Tele with the old butterfly style. As many know, two holes are required for the roller guide, one for the screw and one for a little post that keeps it straight. The butterfly guide actually covers about half of the second hole and I'm wanting to fill with something close to the color of the maple.
I've read about using toothpicks stained with coffee. Really just looking for a simple solution. Since only half of the hole is visible and the guitar is far from showroom quality, not looking for perfection.
Mr. Jinx is offline   Reply With Quote
Old May 14th, 2008, 11:36 AM   #2 (permalink)
Moderator
getbent's Avatar
I used a little wood putty that matched the color pretty closely and I've used a little piece of wood from the same neck (from another spot) and superglue and just superglue... I liked the results of the wood putty the best.
Happiness makes up in height what it lacks in length.
Old May 14th, 2008, 12:09 PM   #3 (permalink)
rhomco's Avatar
Well if it is already finished
matching can get a little complex. You want to avoid "End Grain" such as the old toothpick idea because it soaks up and darkens the finish more than the wood surrounding the hole you are trying to hide. If I have bare wood, I like to scoop out a small piece of maple scrap with a 1/2 round chisel and super glue it in place into a similar scooped out hole over the hole I want to hide. After level sanding you cant find it unless you have strong grain patterns to deal with.
Good luck on this one,
Rob
If I won the Lotto.... I'd just build (OK, OK Assemble) guitars and sell them till the money ran out
rhomco is offline   Reply With Quote
Old May 14th, 2008, 03:23 PM   #4 (permalink)
jwells393's Avatar
How about a wax stick. You can probably find them at just about any hardware store. They're used to fill nail holes in things like natural wood door trim and baseboards. They're available in a variety of wood colors. just rub it on the hole until it's filled then polish with a cloth.
Old May 14th, 2008, 03:34 PM   #5 (permalink)
Vizcaster's Avatar
I'd go with the wax stick since it's reversible. Your goal is to make it less noticeable, since you can't make it disappear without some refinishing.
Old May 14th, 2008, 09:58 PM   #6 (permalink)
mellecaster's Avatar
+3 on the Putty Stick...don't overthink a simple cosmetic repair.
Old May 14th, 2008, 10:30 PM   #7 (permalink)
braderrick's Avatar
Cool Jack, never seen that stuff. Time for a trip to the store, maybe time for me to fill some of those unsightly holes in some of my headstocks too.
braderrick is offline   Reply With Quote
Old May 15th, 2008, 09:50 AM   #8 (permalink)
Great ... thanks for the tip. Didn't know that stuff existed.
Old May 15th, 2008, 12:01 PM   #9 (permalink)
red57strat's Avatar
I used a similar pruduct that came with my kitchen cabinets. It worked great.
Don
red57strat is offline   Reply With Quote
vB code is On
Forums Directory
