Old May 12th, 2008, 09:59 AM   #1 (permalink)
Squire Standard Tele Pickup question
Does anyone know what "type" of pickups these are? Alnico V or Ceramic? I've got a Standard Tele and I took out the pickups and replaced them with some GFS pickups before even giving a good listen to the pickups a long time ago. Now, I'm looking for more of a low output type sound, playing alot of full chords with a little overdrive, 60% clean mix with 40% overdrive mix from a Sparkle Drive. My hotrail type pups are just too over the top!
Was wondering if it would be better to put the original pickups back in the tele or should I start looking at some type of DiMarzio or Seymour? I don't have the $$$ to drop on a set of custom wound.
Thanks,
Jeremy Steger
Mods, move this to the Pickup forum if it would be better to be there. I wasn't sure where to put this post.
JKSteger is offline   Reply With Quote
Old May 12th, 2008, 10:26 AM   #2 (permalink)
Steve G's Avatar
Give em a listen before you decide. Theyre alnico pickups in the standard model. If you decide to replace check out Bill lawrence keystones, they get a lot of praise around here.
"He was a drinkin' man with a guitar problem..."
http://www.myspace.com/stevegiddings
http://www.myspace.com/hiandlonesome
Steve G is offline   Reply With Quote
Old May 13th, 2008, 08:23 PM   #3 (permalink)
telecaster1987's Avatar
Thanks,
Jeremy Steger
What GFS hotrails did you put in? I have a set of vintage moderns on order that are supposed to be shipped in a couple of weeks.
Roses are red, violets are blue,
I'm schizophrenic, and so am I!
Sure, I work on electronics...It doesn't bother me... bother me... bother me...
telecaster1987 is offline   Reply With Quote
Old May 13th, 2008, 08:27 PM   #4 (permalink)
Telecaster1987
I think they are the Modern HOT. Looking for a thick, Les Paul "type" sound at the time with lots of distortion.
J:
Old May 14th, 2008, 12:27 AM   #5 (permalink)
bowlfreshener's Avatar
According to the specs on the Squier website the pickups on the Standard Series are Alinco.
RAMA LAMA FA FA FA
bowlfreshener is offline   Reply With Quote
Old May 14th, 2008, 08:45 AM   #6 (permalink)
amx1's Avatar
yup, alnico V magnets. i found mine to be VERY bright, almost shrill at times. they come with 500k pots so maybe 250k pots would tone it down a bit.
amx1 is offline   Reply With Quote
Old May 14th, 2008, 08:59 AM   #7 (permalink)
RotelliCaster's Avatar
I like the pickups in my Affinity, they can be a little thin, but sometimes that fits my mood.
Bill Lawrence pickups are fantastic and not pricey at all. Tonerider Vintage plus are excellent pickups too, also not pricey. The Toneriders VP's are Clean classic Tele pups and they look correct.
" Trust me, I saw this in a cartoon and I'm pretty sure I can do it! "
http://www.myspace.com/bmwsteve
RotelliCaster is offline   Reply With Quote
vB code is On
Forums Directory
