Old May 10th, 2008, 04:59 PM   #1 (permalink)
Humbucker routing
I'm about to assemble my first partscaster, and would like to rout the neck pickup cavity for a humbucker. Is it as easy as just drawing how big the new hole should be, and then just "cutting" it out with a Dremel or something?
teejoo is offline   Reply With Quote
Old May 10th, 2008, 05:09 PM   #2 (permalink)
jwells393's Avatar
Here's a PDF of a Humbucker routing template. When the Adobe Reader print window opens, set "Page Scaling" to "None". It should print actual size. To check, the width of the opening should measure 3 7/16 in.
HumTemp.pdf
Old May 13th, 2008, 07:51 AM   #3 (permalink)
to make this easier, take that template that he gave you, and use either plexy, scrap wood or ply that is about 1/2 inch thick. transfer the pdf template too it, cut it out and make a nice smooth copy of it in the "template material" then you can use a router equipped with a template bit to follow the template you just made to cut the cavity.
just mount that template and follow it with a router. take a few trial passes before messing with the guitar and you should be good.
might be tough with a dremel, not to mention tough on the dremel.
ndeli55 is offline   Reply With Quote
Old May 13th, 2008, 08:32 AM   #4 (permalink)
amx1's Avatar
is there a single coil neck cavity already? i am modding my squier standard, i had to plug the neck pup cavity with a solid block and then re-rout for the humbucker. not a big deal, just had to make sure the plug fit nice and snug, but not so tight that it would crack the body. here are some pics.
amx1 is offline   Reply With Quote
Old May 13th, 2008, 09:10 AM   #5 (permalink)
jwells393's Avatar
amx1..............I'm curious as to why you needed to plug the neck cavity before routing. Was the original rout sized for a Strat pickup? Here I've put my humbucker template over a Tele pickup rout and it looks like it would work without plugging first.
Old May 13th, 2008, 01:53 PM   #6 (permalink)
That is exactly what I did. Lined up the centerline with the seam in the body, and the top of the template with the top of the existing rout. Worked just fine.
mlp-mx6 is offline   Reply With Quote
Old May 14th, 2008, 10:27 AM   #7 (permalink)
Looks like maybe the original pickup rout was a P-90?
Old May 14th, 2008, 02:27 PM   #8 (permalink)
How do you secure the template to the body so it doesn't move when the router bumps into it?
Zhangliqun is offline   Reply With Quote
Old May 14th, 2008, 03:13 PM   #9 (permalink)
eryque's Avatar
Heavy double stick tape and a clean surface. Don't push the router against the template too hard.
Old May 14th, 2008, 03:13 PM   #10 (permalink)
jwells393's Avatar
Double sided tape will hold it in place if you don't exert a lot of side force on the template. The tape that looks sort of like cheese cloth works well. I usually pre-drill my cavities with a drill press and Forstner bit before using the router.
Old June 26th, 2008, 06:01 PM   #11 (permalink)
Yes, you could try doublesided tape. I just make my templates big enough to clamp to the top of the guitar. That way they won't move. I nearly spoiled a neck this way- the tape let go during a router pass and I cut a bit too deep. Luckily it was on a part that needed additional trimming, so I was saved. I wouldn't trust the double sided tape too much!
If they give you lined paper...write on it the other way.
erickhanson is offline   Reply With Quote
Old June 27th, 2008, 08:28 AM   #12 (permalink)
Or, you could screw the template to the body using the mounting ring holes.
Old June 28th, 2008, 12:29 PM   #13 (permalink)
JasonRobert's Avatar
it looks like it was routed for a p90 as reddogbass said, and the holes for the surround would not be able to be drilled, because there is no wood to be drilled into.
JasonRobert is offline   Reply With Quote
