Old April 27th, 2008, 08:18 AM   #1 (permalink)
Standard Tele Wiring, extra ground wire?
I've been looking at a few of the T drawings on this stuff..some show a ground wire to the plate, some don't?
I don't think nay of the teles I've owned had an extra wire the few times I took the plate off to swap pickups over the years.
Any advise?
Thanks in advance.
http://www.seymourduncan.com/support...=standard_tele
littlejohn is offline   Reply With Quote
Old April 27th, 2008, 09:35 AM   #2 (permalink)
jwells393's Avatar
It can't hurt and I've found it can help reduce noise.
Old April 27th, 2008, 11:33 AM   #3 (permalink)
surfoverb's Avatar
Any advise?
Thanks in advance.
If your bridge PUP has a metal bottom plate then you don't need it...You can opt to still use one but you don't need one unless, you feel you really need one.
"You released the ******* fury!"
Old April 27th, 2008, 11:49 AM   #4 (permalink)
PhatTele's Avatar
In a Tele, you should always have at least 3 wires coming from the bridge cavity: 1 hot PU lead, 1 ground PU lead, and 1 shielding lead (which goes to ground). That shielding lead is what connects the strings to ground and what helps keeps things safe and what helps reduce the 60 cycle AC hum. Nearly every properly wired guitar has some version of that shielding lead. In Gibsons, the lead goes to the bridge posts. In hollow bodies with trapeze or Bigsby end pieces, there's a bare wire that goes to one of the small bracket mounting screws at the butt end of the guitar. In Strats, there's a ground wire soldered to the spring claw. In each of these cases, the wire is tracing a connection from the strings to ground.
Old April 27th, 2008, 11:59 AM   #5 (permalink)
surfoverb's Avatar
What about Teles? Mine don't have a 3rd wire and its grounded just fine...Lol maybe Leo got it wrong the first time afterall.
Old April 27th, 2008, 12:22 PM   #6 (permalink)
mellecaster's Avatar
Agreed...Just because Fender didn't do it on all, means nothing...a separate ground is much more reliable than (3) 6/32 machine screws that can become dirty w/ crud and the like....it's a Real World Solution, that takes very little extra time, and just eliminates one more little Gremlin that can happen during a Performance.....in your living room, maybe not so much ?
I have never owned an Ipod or Blackberry..and doubt that I ever will......
Old April 27th, 2008, 01:50 PM   #7 (permalink)
PhatTele's Avatar
In Teles, that 3rd wire should be touching the bridge plate (not screwed into the wood, which I've seen...which doesn't make sense to me).
BTW - Maybe not having isolated grounds within the wall wiring back in the early days meant Leo left out the shielding wire on the earliest Esquires and Teles because it wouldn't have made any difference? Now that we have that ground wire in the wall, it's a good idea to take advantage of it.
Old April 27th, 2008, 02:01 PM   #8 (permalink)
surfoverb's Avatar
That's interesting.
I don't like the idea of having a wire crammed under neath the bridge, doesn't that affect the coupling?
What's great about the CIJ bodies is that they have a route going to the control under the bridge so the bridge will still be flush if you choose to put a wire under it.
Old April 27th, 2008, 05:06 PM   #9 (permalink)
PhatTele's Avatar
I use multifilament cloth covered wire or some other multifilament wire. I strip back the casing and splay/fan out the filaments before putting them underneath the bridge near the bridge screws (between the bridge plate and the body). The individual filaments are very thin, so when everything's screwed down, there's no gap. Sometimes, I even angle a small hole from underneath the plate into the PU cavity and then run the splayed wires. That's the method I like the best.
Another way to do it is to put a solder lug over one of the PU screws between one of the springs (metal or rubber spring...it doesn't matter) and the bridge plate and then run the wire from there. I think you get more solid contact with the first method, but if you're worried about a gap, this is probably the best alternative.
Old April 27th, 2008, 09:44 PM   #10 (permalink)
This ain't Super Hi-Tech...but it works for me.
Old April 27th, 2008, 09:58 PM   #11 (permalink)
newey's Avatar
It may help reduce hum. It has nothing to do with safety.
My Tele needs an F Hole.
newey is offline   Reply With Quote
Old April 27th, 2008, 10:57 PM   #12 (permalink)
jwells393's Avatar
mellecaster............ that is cool....
