Old April 26th, 2008, 03:40 PM   #1 (permalink)
Tele popping/crackling noise
I can't figure this out. My MIJ Tele makes a popping/crackling noise when I move it around. It's fairly intermittent and unpredictable and does it in all pickup settings. When I wiggle (not turn) the volume or tone pots or pickup selector. It also seems to make more noise than normal when I tap on the body in all pickup selections (especially the bridge). Are my pickups microphonic or is it a grounding/shielding issue? The noise is obviously more noticeable when I am using higher gain amps or pedals. Help!!!
ttingley is offline   Reply With Quote
Old April 26th, 2008, 04:15 PM   #2 (permalink)
MulliganChebichev's Avatar
Read this and shield your body
MulliganChebichev is offline   Reply With Quote
Old April 26th, 2008, 08:28 PM   #3 (permalink)
Guitar_Ninja's Avatar
Does your bridge pickup have a baseplate? The baseplate on mine recently got loose and went microphonic. When you switch over to the bridge pickup does it make a loud, hollow pop? If the baseplate is loose you'll need to take off the bridge plate and drip wax onto the bottoms of the pole pieces, then push the baseplate back on. If there's any air between the baseplate and the bottoms of the poles you'll get that microphonic sound.
Guitar_Ninja is offline   Reply With Quote
Old April 27th, 2008, 09:55 PM   #4 (permalink)
Geo
Geo's Avatar
It is most likely static build up so just spray with contact cleaner or
WD 40 in each switch position and move the switch back and forth
after to spread it around. Even the Fender Japan switches will accept it
with no problem.
"Somewhere between culture and agriculture"
Geo is offline   Reply With Quote
