Old April 26th, 2008, 09:42 AM   #1 (permalink)
eddiewagner's Avatar
saddle height for bigbsy installation
hi friends,
i have been fiddling with one of my teles to get it right, before the bigsby comes. i put one strip of credidcard and one layer of cloth-tape under the neck to chim it up. this is the highest i can get the saddles up while having the right stringaction. do you think that is enough to have a good angle for the strings? i really do not want them to pop off the saddles, because i play quite hard. you are reading a millimeter ruler. how high are your saddle from the body on your bigsby-teles?
thanks,
eddie
My Drum/Guitar-Duo:
www.myspace.com/captaintwangandhisrhythmcat
Old April 26th, 2008, 12:25 PM   #2 (permalink)
jwells393's Avatar
Eddie ............ since you have a top-loader there I will assume you have ordered a complete B-5 kit. The following was measured on a CIJ factory installed B-5 F Bigsby
Top of big E saddle to bridge: 8 mm
Bridge above Bigsby plate: 2 mm
Bigsby plate above body: 2.5 mm
Total saddle height above body: 12.5 mm
Old April 26th, 2008, 01:14 PM   #3 (permalink)
thanks for the precise info jwells!
it may look like a toploader, but it is a drilled and filed bridge of a squier custom 2. i will bolt a duesenberg tremola to the guitar.
My Drum/Guitar-Duo:
Old April 26th, 2008, 06:19 PM   #4 (permalink)
RomanS's Avatar
Eddie, here are som old pics I took a while ago:
- I think you'll easily be OK with your saddles/screw, the string-break angle is much more flat on mine, and I do play hard, too!
Oh, and I know where your Duesenberg is coming from....
I'll put it in the mail first thing Monday morning...
Old April 26th, 2008, 06:21 PM   #5 (permalink)
RomanS's Avatar
...found one more picture!
Old April 26th, 2008, 06:56 PM   #6 (permalink)
he roman, this is good news all the way. your angle looks surprisingly flat.
maybe it works so well, because of the corners of your special saddles. i have one grapphtech for the low strings, and two regulars with deep notches for the treble strings. right now i have set the intonation right, because i guess with the duesenberg mounted it will be too late. tactics, you know...
eddie
My Drum/Guitar-Duo:
