Tele Body edge band?
I have a 2005 MIM Tele (Black) that I bought damaged from a dealer. It has a few places with some chips and areas where the finish is still adhering but cracked.
I removed one piece of the finish that was cracked and semi sharp, to make that spot smoother and founs what looks like some kind of darker material used as an edge banding around the body. Is this normal, or is Fender really cutting corners? I understand a multiple piece body, but this is kinda what is done to finish the edge of plywood! any thoughts? |
| Sponsored Links |
Your description is unclear. We like to see pictures. Look in the control cavity ..........you could tell if it was plywood. I seriously doubt Fender is using plywood. Plywood was once used on some of the cheaper Squiers and is used on the Squier Mini-Strats.
Jack's Disclaimer: When I say something.... always ask yourself ..... "What the hell does he know?" _ ![]() Guys - learn to disable the flash on your digital cameras. |
The photos are almost worthless (sorry) but are you talking about the part that I circled?
untitled.JPG I'm wondering if this could be the edge view of the top coat?
It was born at the junction of form and function... |
If you want to repair it I'd recommend that you break away all of the thick poly finish around the damaged areas. Then use auto body filler to build the damaged areas up the the surrounding surface. You're lucky it's black. You should be able to touch up the repair with Krylon and Deft. Here's a big poly chip I repaired with Bondo.
Jack's Disclaimer: When I say something.... always ask yourself ..... "What the hell does he know?" _ ![]() Guys - learn to disable the flash on your digital cameras. Last edited by jwells393; April 25th, 2008 at 01:30 PM. |
Thanks for looking at the pics, I know they are not the best, but the first one shows the line between the edge banding material and the body wood pretty well. the circled area is less clear, but i can actially get a razor blade edge into the joint. It appears that the body wood is solid,and perhapse they use this other material to make the edge finish and slight raduised edge?
I had thought about stripping the body and refinishing it, but it looks like the edge banding would make that a pain in the arse. I have never heard anybody mention this as a factor before, so wanted to: See if it was common. Let others know about it. |
Stripping these has been much discussed in the past and you are correct - it will be a total pain in the arse! You might be better off looking for a new body on ebay.
Ima gonna side with Nick on this a speculate that we are looking at a veneer.
But I have been wrong before. Nick, I am not so sure about. Maybe once, about 6 months ago. Since then he has had a pretty good streak going.
Veneer +1
I have heard [read] about refinishes of MIMs which have uncovered 6-7 piece bodies with a veneer on the front and back. I suspect that is the case here quite possibly. The veneer will let the seams show through less obviously, or not at all?? It has got to take one serious hell-ova shoot to get a chuck of finish off these poly*.* finishes. |
#16 (permalink) | |
This guitar fell off the wall hanger at the dealer, and had a few chunks out of it. Tele headstock shapes do not stay in the hanges very well I guess. I bought it for $300 as a beater (but then put 4 way switching, SCNs and Fender/Schaller locking tuners on it, so not sure what it is now. a nice beater?) |
