Old April 23rd, 2008, 07:17 PM   #1 (permalink)
GuitarJonz's Avatar
Guitarfetish klusons
Anyone tried the Guitarfetish Kluson style tuners and conversion bushings? Looking for a review.
Conversion Bushings
Kluson-style tuners
Old April 23rd, 2008, 09:31 PM   #2 (permalink)
Doug Ferguson's Avatar
Conversion Bushings
Kluson-style tuners
Just installed these on a Squire Affinity, along with the bushings. The bushings press fit nicely into the pegholes -- no filing necessary (YMMV). I did need to file the edges of the tuners to get them to lie flat on the headstock. Nothing major -- just a bit off each side of each tuner (again, YMMV). You might want to go with the one's that are $5 more than the one's you're looking at. I know they've got the center hole and are constructed with better material to control backlash. I'm happy with them, They work well and look nice and vintage.
If you get hung up on just guitar players, you've missed something.... Don't ever get to a point where you just gotta be a guitar player. You hear something, go try to get that note and sound as much like that as you can.-Buddy Guy
Doug Ferguson is offline   Reply With Quote
Old April 23rd, 2008, 09:37 PM   #3 (permalink)
jwells393's Avatar
Doug ......... are those Wilkinsons split shaft? Can't tell from the Guitar Fetish ad>
Old April 23rd, 2008, 09:39 PM   #4 (permalink)
That they are, Jack. Great tuners for the price.
Old April 23rd, 2008, 09:56 PM   #5 (permalink)
I bought some of the GFS Klusons for a new neck I' putting on my Squier VM Thineline but, since I have only now finished shooting lacquer on the neck, I haven't actually put them to use yet.
I can tell you this, they appear to be very well plated and made, feel solid, and are nearly identical in appearance as the Gotoh's. Their dimensional specs are slightly different from the Gotoh specs:
the "inner" 4 machines measure .941" in length as opposed to the Gotoh's .932".
the "outer" 2 machines measure 1.103" in length as opposed to the Gotoh's 1.115"
the posts stand a tad taller at 1.045" as opposed to the Gotoh's .965"
the posts diameters are slightly slimmer at .236" as opposed to the Gotoh's .249"
These are split shaft tuners.
As you see all of the visual differences are basically a thousanth of an inch here and there - close enough that I would call them "direct replacement".
However, the functional differences remain to be known. I figure, if they aren't up to snuff for my thinline, I can always yank them, get conversion bushings and put them on my Affinity tele. I should then be able to drop the Gotohs in w/out patching screw holes.
Sorry I couldn't be of any more help.
crowden is offline   Reply With Quote
Old April 24th, 2008, 01:29 AM   #6 (permalink)
Ringo's Avatar
what about the Wilkinson vintage tuners ?
http://store.guitarfetish.com/wiklstnitusi.html
I asked about the Wilkinson vintage style tuners a while back, they look a bit nicer than the cheaper ones that GFS sells, anyone tried them?
Old April 24th, 2008, 06:18 AM   #7 (permalink)
BlimpyBoy's Avatar
I put the Wilkinson's on a MIM Tele neck I sold on eBay. I'd previously fitted original Fender "Kluson" tuners to the neck, but removed those to use on a new CIJ neck. Are you with me so far!
The Wilkinsons fitted very well, and the bushes fitted nice and easy. In terms of quality of finish and fit they were very very close to the Fenders. I never fitted the MIM neck to a body so I can't say how they play, but they look the part and the build quality is great.
I swear I found the key to the universe in the engine of an old parked car.
BlimpyBoy is offline   Reply With Quote
Old April 24th, 2008, 09:25 AM   #8 (permalink)
bnjp's Avatar
I've used them twice now and really liked them. Here's a closeup.
bnjp is offline   Reply With Quote
Old April 24th, 2008, 11:41 PM   #9 (permalink)
JDRNoPro's Avatar
I used those recently and thought they were very nice at a reasonable price - seem to compare fairly well to the pings that come on MIM Classic series. Mine operate smoothly and hold well and the nickel plating looks good.
Jim
Reflection upon my playing is a reminder to keep my regular job..........pays better but not nearly as enjoyable!!
JDRNoPro is offline   Reply With Quote
Old April 25th, 2008, 11:37 AM   #10 (permalink)
A set of Kluson copy made by Wilkinson (http://store.guitarfetish.com/wiklstnitusi.html) that I received from Guitar Fetish was horrible. Each tuner had a lot of slop and all had wobbly shaft. The wobbly shaft may not have been such an issue, once they are mounted but the slop was quite bad.
WrapAround is offline   Reply With Quote
Old April 25th, 2008, 11:43 AM   #11 (permalink)
I put the "double line" Wilkinsons on a Squier 51, with conversion bushings. Mounted with no issues, and they work fine, just as well as OEM Fenders, and real "Kluson" repros.
I think that Wrap may have gotten a bad set.
allen st. john is offline   Reply With Quote
Old April 25th, 2008, 02:28 PM   #12 (permalink)
spankdplank's Avatar
I have used several sets of the GFS generic Klusons, not the Wilkinson ones. They looked great, held tune, and turned smoothly. I was very pleased. All of the sets I have ordered came with solid shafts, however. I think the Wilkinson ones are split shaft and the GFS generic are solid, bit I'm not sure.
spankdplank is offline   Reply With Quote
Old April 25th, 2008, 07:05 PM   #13 (permalink)
Billy Claire's Avatar
Conversion Bushings
Kluson-style tuners
I've been wondering overall about Guitar Fetish since they're right near us, John, in Medway!
www.myspace.com/sherylamour
www.theallens.theallens.com
tear off my arms and beat me to death with them...
Billy Claire is offline   Reply With Quote
Old April 27th, 2008, 03:16 AM   #14 (permalink)
PJ
PJ's Avatar
Of all the vintage tuners I've used, the Grover Deluxe, from International Luthier Suppy (www.internationalluthiers.com)
seem to be the best - at least as good as Klusons or Gotohs.
And they've dropped-in to both vintage and reducer bushing
applications without problems. (Grover #G133N6)
PJ
"I don't know if it's art, but I like it."
PJ is offline   Reply With Quote
