2 birds 1 stone-neck shim
There were 2 problems with my squier '51(in fact there are more, but these are related
Last night, I had an epiphany... I should shim the neck! I took a piece of board (thickness of a cereal box) and taped it to the part of the neck base closer to the bridge. This caused the neck to tilt back. With a tilted neck, the saddles must be raised to compensate. At perfect action... the screws were mostly flat with the saddles. Also, the screws did not come loose anymore since the higher saddles provided a sharper break (more downwards force) that kept them nice and snug. If any of you have cheap annoying 6-saddle bridges, you should give it a try!
Check out my bands, and feel free to PM me comments on them! The Eclectics (guitar/vocals) SLIP (bass) |
| Sponsored Links |
I had a similar experience when my RS Guitarworks Tele showed up. It was used and I ordered it from a reputable shop, but when it arrived it had the neck shimmed at the furthest point from the neck heel. It was a THICK shim and there was a big gap between the neck and the body. Oddly, the saddles were down against the bridgeplate. I'm thinking, "Why is this neck shimmed?"
I pulled the shim out of the neck, re-set the action, and the guitar is perfect! A nice mid height to the saddles. Why did someone stuff all that crap in the neck pocket? I'm still confused. Congratulations on getting your guitar working correctly!
Just because I "Don't" get it doesn't mean I "Won't" get it! |
That's exactly what I did with my '51. Improved it no end for about an hour's effort as well as allowing a lower action.
Helping to invent english country dance guitar since 1981. |
A fellah here a TDPRI solved this problem a long time ago, by the name of Mike Levitt. I'm thinking November of the first year the Squier 51 was introduced.
The cold fact is the 51 stock bridge assembly as designed is a total mess, and that's why the guitar was discontinued, IMO. The strings and the saddles are competing for the same real estate, and the strings, which should only be pressing the saddle hard down onto the bridge plate, spends almost as much effort levitating the saddles, hence all the junky sounds, loose height screws, inability to intonate, and saddles actually falling over when played hard. There is nothing short of converting the guitar to string through that can rehabilitate these saddles, again my opinion. Go to Institute of Noise, Squier 51 Modders Forum and see all the guys switching to this 3 brass barrel mod, that Mike invented. Stop killing the 51 Spring songbirds with stones, I mean shims.
Bubban0v |
