Old April 29th, 2009, 04:21 PM   #101 (permalink)
scubadoo's Avatar
Thanks Jack! That is really helpful.
I will definitely check out Bill's thread (thanks Bill).
I'm still trying to get my head round building a neck and what do you know, enough timber to build a quilted maple capped thinline and a Les Paul has just arrived! I'm planning on reading and re-reading as much stuff as I can and just taking it slowly.
Not sure I'm up to it but we'll see.
Best wishes
Dave
scubadoo is offline   Reply With Quote
Old June 1st, 2009, 09:54 AM   #102 (permalink)
I have been following your neck building thread with interest. I have my blank cut and built my own truss rod. I am having a difficult time making the jig to cut the truss rod slot. I have drawn out a quite a few templates and seem to get it wrong each time.
Would it be possible to post some basic dimensions of your jig?
Regards,
woodturner is offline   Reply With Quote
Old June 1st, 2009, 10:12 AM   #103 (permalink)
scubadoo's Avatar
Regards,
Are you particularly hung up on the vintage style rod? If it was me, and bear in mind that I'm only on my first neck, I would get one of the single- or double-action rods that sit in a flat bottomed slot like in this post http://www.tdpri.com/forum/1846206-post2.html. You don't need a curved channel and you don't have to worry about anchoring at the headstock end and filling the hole. The only 'jig' you need is to clamp the neck down and clamp a straight edge parallel to your centreline that either your router base or 1/4" router bit can run against.
I'm sure Jack will come in, but you can make a jig for the curved truss rod channel by using the strat neck cross-section that he has posted a few times. Have a look in Bill Scheltema's thread as well.
Cheers
Dave
Old June 1st, 2009, 10:21 AM   #104 (permalink)
Hi Dave,
Thanks for the quick reply. I made up the truss rod from the info in the strat neck blueprint. I also used that to make the side templates for routing the curved recess. I'm having difficulty getting the templates orientated to the blank so that the proper curve and depth will be cut.
This has been a reality check for me. I can carve a wooden propeller but can't seem to build a jig.
I might have to try the straight slot style truss rods. I can always use the truss rod I built in the next one.
Thanks Again,
Bill
Old June 1st, 2009, 10:22 AM   #105 (permalink)
ChicknPickn's Avatar
Another bookmarked thread from Jwells . . . .
Man, this is good stuff.
Tim in VA
ChicknPickn is offline   Reply With Quote
Old June 1st, 2009, 10:36 AM   #106 (permalink)
Hi Dave,
Thanks Again,
Bill
Don't feel bad, you're not alone. I think I'm on my 5th truss jig and am just starting to get to where I want to be. For whatever reason, I'm finding it particularly difficult too. I've cut a few slots that I could have salvaged, but I'm trying to get a quality result along the lines of what jwells, and preeb, and Scatter Lee and these guys get, so practice practice practice has been my mantra. Thank goodness wood is cheap...
My current jig looks a lot like the one posted here except instead of an edge guide, I put a 'wall' on one side and keep the router base pressed against that wall as I ride the rails. I have a toggle clamp like the one shown to hold the headstock down, but I need a clamping solution for the heel. The rails and the stop for the end of the heel end of the truss channel are preventing me from fitting a clamp in there. So I need to solve that somehow. I tried just sticking the heel down with double-sided tape last time, and it wandered and ended up screwing up the slot...
I have a couple Stewmac Hot Rods here and could just put in a straight channel for them, but now I'm kinda bull-headedly determined to tackle the vintage truss first.
ratter is offline   Reply With Quote
Old June 1st, 2009, 11:50 AM   #107 (permalink)
Jack Wells's Avatar
I'm not sure what help is needed for building the curved channel jig. I'll go into a little more detail on how I built mine. First, I'll show the Strat neck blueprint once again.
As you can see the curve is made up of two radii..... 115 inches on the headstock end and 255 in. on the heel end. I used a 25 ft. tape measure to draw these curves on a piece of poster board. I put a screw in a board and put a weight on it then attaced the end of the tape measure to the screw. I then went to the 255 in. mark ......... aligned my pencil and swung the tape measure to draw a curve that intersected a straight line aligned with the centerline of the tape measure. I then did the same at the 115 in. mark positioning the poster board so the 115 in. mark on the tape aligned with the previous curve.
With the complete curve drawn on the poster board. I then cut it out and trace it to a piece of wood. I cut close to the line with a bandsaw then sand to the line. I then rip the piece in two giving me the two curved rails the router base rides on.
From the drawing, you can see that the centerline of the radii is 8.745 in. from the nut slot. From this centerline, the channel should go 6.745 in. toward the headstock and 9.060 toward the heel (for a headstock adjust neck....... on a heel adjust neck this dimension would be ~ 7.25 in.). Where you put the stops on your jig to determine the ends of the channel will depend on your router and the dimension of the base plate.
Since routing the channel is the first step, my jig is attached to the neck blank with screws in locations that will be cut away when the neck shape is cut.
I start the routing at the radii centerline point with the bit just touching the wood. Consider that the zero depth reference point. I then set the depth on my plunge router to make shallow passes until I have it set 0.495 in. below the zero reference point.
Here's a better picture of my channel jig. I've marked the following reference points: Nut line, End of channel, High point (radii centerline) Vintage end of channel and Modern end of channel.
I hope this helps. I'll try to answer any other questions.
Old June 1st, 2009, 12:39 PM   #108 (permalink)
Canadianbreed's Avatar
Woodturner
It all depends on what type of side rail you are using.
I used a 1-1/2" piece of wood which I used to rout the arc into. I made a matching mirrored rail for the other side they are 6" apart because my router sits in between the rails keeping it steady as I run along the rout path.
What you could do is make the arc pieces first then add outside pieces to get the same effect.
Or...
Forget the outside pieces and do what Jwell does with his guide. Both will work.
Bill
Canadianbreed is offline   Reply With Quote
Old June 1st, 2009, 07:11 PM   #109 (permalink)
Thank you very much ... Drawing the arc was causing me grief. Your explanation cleared that up. Looks like tomorrow I'll be cutting wood.
Thanks Again.
Old June 1st, 2009, 07:28 PM   #110 (permalink)
I took ehawley's drawing from his cnc thread of the neck profile, printed it out, stole my 4-year-old's glue stick, and glued it to 1/4" mdf. Then I cut that on the bandsaw and made a template that I used to route thicker stock to make the actual rails.
Old June 1st, 2009, 09:50 PM   #111 (permalink)
Side dot position
Hi JWells,
I just glued in my fret position markers and am ready to drill in the side dot markers, what distance did you go from centre of dot to edge of fingerboard, about 1/8"?
Bill
Old June 1st, 2009, 11:33 PM   #112 (permalink)
edd677's Avatar
I just bought a rigid spindle/belt sander tonight. Have you had any problems finding replacement spindles? I hear HD does not sell them, even though they sell the sander.
edd677 is offline   Reply With Quote
Old June 2nd, 2009, 12:36 AM   #113 (permalink)
PennyCentury's Avatar
JWells,
I'm late to this thread. I had an idea with respect to the mini-Tele and proportions.
The stock Tele control plate seems to me to be out of scale to match the dimensions of the otherwise smaller guitar. I would think one of the folks here might be able to supply a shorter control plate. I don't know if someone could make a pair of smaller diameter knurled knobs; mini pots are a possibility. Maybe remove some metal around the perimeter of the stock Tele bridge.
Just a small suggestion...
Regards,
Penny
PennyCentury is offline   Reply With Quote
Old June 2nd, 2009, 08:25 AM   #114 (permalink)
Jack Wells's Avatar
Bill ......... It's been so long since I drilled the side dot holes, I don't remember how far they were from the fretboard surface. I probably just measured on a Fender neck and went with that.
Edd677 .......... When I bought my Ridgid sander Home Depot didn't have the spindle sanding sleeves. However, I think I saw a package of them on a recent visit. I ordered sleeves from Grizzly. They're also available from Woodworkers Supply.
Penny ........... you're right about the control plate being out of scale for a small guitar body. I have another thread started on building a Mini-Telecaster.
Designing and Building a Mini-Telecaster
I've cut down a regular control plate by cutting at the tone control hole and drilling a new hole. Here are pictures of the smaller control plate. I think the bridge must be left as is.
Old June 2nd, 2009, 05:03 PM   #115 (permalink)
Oh, that mini Tele mockup is -- you should excuse the expression -- so cute!
And the bridge doesn't look out of scale at all.
You've got another winner!
Old June 9th, 2009, 08:48 AM   #116 (permalink)
Jazzmeister's Avatar
Originally Posted by jwells393 View Post
I made a neck template from 3/4 in. MDF. This thick template allows me to start the shape routing with a shallow pass on the router table. I do the neck shape routing on the router table using a pattern following bit (the bearing is below the cutter when mounted in the table) making several shallow passes .......... 1/4 in. or less.
Jack, thanks for the great tutorial. When you route with shallow passes as you mention, does it eliminate the tendency to grab the neck around the headstock curves and tearout? Any other tips on this? I've been having a heck of a time getting this done without some mishap. I had bascially given up on using the router on the headstock and was just going to take it down with the spindle sander.
Jazzmeister is offline   Reply With Quote
Old June 9th, 2009, 09:42 AM   #117 (permalink)
Jack Wells's Avatar
Shallow passes are especially important on hard maple. Another important thing is "downhill routing". Problems can occur on the end of the headstock if you go the wrong way. I've posted a picture showing downhill routing on a body. Guess I should make one up for a headstock.
Edit: Here's that downhill routing guide for the headstock. After you've done a few bodies, the downhill routing becomes second nature. In the sections marked with an "X", you're not pushing against the rotating cutter, therefore you need to hold on really tight so the router doesn't grab the workpiece........ another reason for shallow passes.
Old June 9th, 2009, 10:37 AM   #118 (permalink)
I wanted to say thanks to you Jack for the great thread. Largely because of this thread and preeb's threads, I'm nearing completion of my one-piece neck. I figured some things out the hard way, but (surprise, surprise) when I closely followed the proven methods of the builders here, it really started to come together.
Case in point - these headstock curves...Using the spindle sander like preeb details to get very close to the pencil line (I actually take half the line), leaving just a whisper of wood for the router to take, and then routing in the directions that Jack shows, taking small depth bites each time, and I got a headstock with no tearout, no chipping, and only the faintest burn spot that ended up being on the waste part of the headstock anyway.
So - thanks!
Old June 12th, 2009, 09:45 PM   #119 (permalink)
Hi Jack,
Thanks for the great post.Your work is very inspirational!
I am about to make up the neck drilling jig out of Melvin Hiscock's book,but I was wondering how you made the drill guides up to stop the drill wandering amd chewing out the holes.
His description in the book is a bit vague (good book though!!!!)He mentions using an insert of some kind ?.
Any info would be greatly appreciated.
Regards
Greg
Gregmw is offline   Reply With Quote
Old January 30th, 2010, 09:21 PM   #120 (permalink)
Hi Jack
I was perusing the net and found this sight with great x-rays of the necks and the anchor question I emailed you about.
Very helpful indeed.
trussrod anchor
Bill
