#81 (permalink) | |
All you need to be concerned about is getting the walnut skunk strip snug at the headstock end of the channel. The other end will be in the neck pocket. Many of Fender necks I've seen have a gap in the channel at the heel end. Thanks for the compliments guys. I hope to finish this up soon but my chosen career path is interferring at this time.
. Disclaimer: When I say something.... always ask yourself ..... "What the hell does he know?" I'm just not cool enough to be a Mac person. I'm a PC and Windows 7 was my idea. |
#83 (permalink) |
Hi Jack, new to these forums. Just wanted to know what those lever-type clamps were that you were using to hold down the neck while you drilled out the keyhole for the trussrod at the headstock? Looked like you have built a permanent jig for that.
Thanks Darren |
#84 (permalink) |
Those clamps are called 'quick release toggle clamps'. The should be available from most woodworking stores. I got mine from Woodworkers Supply.
Quick Release Toggle Clamps @ Woodworkers Supply The neck drilling jig is not my idea. I saw something similar in Make Your Own Electric Guitar by Melvyn Hiscock. ......
#86 (permalink) | |
![]() Tele-Afflicted
Truss rod end hole jigs
Jack,
Do you have closeup shots of your truss rod hole jigs? (see my poplar build post) Bill Quote:
#87 (permalink) | |
Jack,
How did you fix the holes that were slightly offcentre? Quote:
My headstock hole is dead on but my heel is slightly off. I drilled using a 3/16" bit, so maybe going to a 1/4" bit will solve the issue if there really is one. Bill |
#88 (permalink) |
3/16 or 1/4
Some silly investigating.
The strat neck drawing calls up a .203 hole through. 3/16 is 0.1875 1/4 is 0.25 13/64 is 0.203125 Don't know of a long drill bit with this dia. so it will need to be a 1/4 for ease of installation. Bill |
#89 (permalink) |
This thread inspired me to join Telecaster Guitar Forum.
I have been contemplating the one piece neck build. These posts are exactly what I needed to gain the confidence to get started. Thanks for all your hard work Jack! |
#91 (permalink) |
Fantastic thread, Jack. Because of you're praise of the Ridgid oscillating edge-belt, SWMBO got me one for Christmas. I noticed from a video tour of the Gibson custom shop that they have a similar ege belt sander with a belt long enough to roll the entire neck at once.
The 4x24 belt is not quite as long as the neck profile, so how did you do it? - did you slide the neck back and forth sideways as you rolled it (two motions at once), or did you roll one area and then move the whole thing along and roll again? By the way, the specs aren't available online or in the manual, but the sanding sleeves are 4-1/2" long which is a standard size in the Klingspoor sandpaper catalog, in case you don't want to buy the full assortment sets from the Depot.
#93 (permalink) |
These measurement are approximate.
With a 2 in. drum the top of the sandpaper sleeve moved between 3 in. and 3 3/4 in. from the table top. With the belt sander attachment tracking true the top of the sanding belt varied from 3 1/2 to 4 1/4 in. above the table top.
#95 (permalink) |
The Ridgid Oscillating Spindle/Belt Sander is on of my favorite woodworking tools. It's great if you use the sand and try method of fitting parts together.
#96 (permalink) |
Hi Jack,
Any more progress on these necks? I've really enjoyed the thread so far. I'm just about to have a go at a tele neck and was wondering if you could answer a couple of questions for me. This may be a stupid question, but what do you use as a guide when you route for the truss rod channel, are you using some kind of bushing on the router base that lines up against your jig? The truss rod i have is one that fits in a U-shaped aluminium housing so would i need to route a flat channel rather than a curved one? How does the Stewmac fret mitre box take account of the fact that the neck does not have parallel sides. Do you have to line it up and clamp it, how do you make sure the fret slots are all parallel? Sorry for all the questions Best wishes Dave |
#99 (permalink) | |
No progress Dave. I do need to get back to neck building because I've built several bodies that need necks.
You should definitely check out Bill's thread. Very interesting neck shaping jig he's developing. I think the StewMac fret slotting miter box is actually intended to cut slots in fingerboards before they are glued to the neck. If you want to use it on a one piece Telecaster neck you need to get a long strip of 1/4 in. MDF that will fit inside the miter box. Draw a centerline down the length of the MDF. Align you neck centerline to this centerline and stick your neck to this with double sided tape. This is what you would do if you were not using the Fret Scale Template. If you're using the Fret Scale Template with the miter box, You would align your neck centerline with a line on the template parallel to the edge of the template. The following post shows how I mounted the miter box to make a jig and shows the neck stuck to the Fret Scale Template. It also show that a Telecaster neck will fit into the miter box to saw the lower frets slots and nut slot but a Strat neck wouldn't allow that. Someone in the forum cut away the back side of their miter box to allow for a Strat headstock. StewMac Miter Box and Fret Scale Template Quote:
#100 (permalink) |
you guys are super talented
Everytime I get on here someone is doing some really cool things. one day I really want to make my own guitar.
www.theorangemonster.com (under construction) so much to design...so little time |
