Resonator Telecaster .......... My Project
I purchased this body on Ebay. It was a beautiful piece of wood and the seller did good work but it appears he copied some non-Fender guitar. It wasn't dimensionally correct. With a neck on, I've measured 25.5 inches from the nut to find my center point. I've drawn circles of 8 3/4 in., 9 1/2 in., and 10 in. I'll be using a biscuit type cone and coverplate. In this picture I'm pre-drilling to remove the majority of the wood.
![]() I've drilled a small hole in the body at the center point of the circles I've drawn. Here you see the rotating template I've made. I'll be using a 1/2 in. pattern bit. The distance from the screw to the outer most part of the template slot is 4 3/8 in. ![]() Here you see the first pass with the router. ![]() I've made patches and have glued them into the ends of what is left of the control cavity route. I also glued a plug into the jack hole since it was drilled in the wrong place. The pillar has been left in the center because there's more pivot routing to do. ![]() Here I've completed the routing using the 4 3/8 in. template. I've gone 1 1/2 in. deep leaving 1/4 in. for the back. I'll make another template that will rout a 9 1/2 in. circle for the biscuit cone. ![]() The original plan was to have a resonator screen just above the neck and to drill a hole that would go from this hole to the under side of the cone to serve as a port. However after routing the 9 1/2 in. opening for the cone approximately 1 3/16 in deep, there wasn't much room to drill a hole that would end up under the cone. I decided not to attempt it and figured the string ferrule holes would act as a port for the cone. So............ the 8 3/4 in routing wasn't necessary. I could have just routed a 9 1/2 in. cavity. ![]() I ordered a biscuit bridge from Stew-Mac. These bridges come with a flat vertical part for use on Dobro style guitars. With a neck mounted to the body and the cone and bridge sitting in the well, I stretched a string from the D tuner across the bridge and sanded the bridge with a fretboard radius block until the action was acceptable. I then put it all together for an acoustic test. Because the tailpiece sits so high on the coverplate, the strings weren't even touching the bridge. I had to add a maple strip to the bridge to build it back up. I had to shim the neck to lower the action with the higher bridge. ![]() Here I've strung it up for acoustic testing. ![]() Time to put it all together
. Disclaimer: When I say something.... always ask yourself ..... "What the hell does he know?" I'm just not cool enough to be a Mac person. I'm a PC and Windows 7 was my idea. |
It's all together although I do have a few bugs to work out ........... intonation for one.
other short Reso tail piece
jwells393 - That is a great looking resotele you built!
I came across another short reso tailpiece - this one I believe is the shorter version as the one you have - it is also not that expensive. Sold by Molonator Guitars on Ebay Molonator Guitars is based Down Under and built Reso guitars - they also made this twinneck aluminium bodied ResoTele ...
Tele Bigsby Count = 315 on my website |
My, that Reso-Tele is sweet!
Excellent job! But...no Pickguard? I guess something in tortoise or pearloid would add to the orange/red paintjob and to its overall look...
Casper: "Mmmmm. Butterscotch, yo. That's the best!" From the movie Kids |
When played without an amp it's really loud compared to a regular Telecaster. Right now with the long tailpiece I'm getting very little break angle at the bridge. A shorter tailpiece with more of a break angle might increase the acoustic volume. I've seen pictures of the shorter tailpieces but have been unable to locate a source. I contacted Molonator Guitars .......... the one he's selling on Ebay is the same size as mine. He's not selling the short one shown in some of his pictures. I not yet ready to spend $90 for the Allen tailpiece.
Right now I have each pickup wired to it's own volume pot. The outputs go to a stereo jack. If I push the mono cable plug all the way into the jack, the neck pickup is grounded out and only the piezo pickup is heard. It has a very metallic sound as you would expect. If I push the plug only part way in till I feel the first detent (both jack contacts in contact with the tip of the mono plug) I can blend the two pickups .......... as long as one isn't completely off ......... If one is completly off both outputs are grounded. I haven't yet used a stereo cable and split the outputs to separate amps. I may add a switch and replace the stereo jack with a mono jack.
very cool work! Man, that's an instant GAS attack right there...
Scott Lentz T - Crook Custom T - Tom Anderson Crowdster - Tom Anderson Atom - Thorn Jr 90 Koa - SRV Strat - Ovation Elite T - Swart AST - Carr Mercury - Fender Tweed Blues Junior. Follow me on Twitter! @MojoCaster |
great job.
i'm interest the reso guitar too, so hard to get in in indonesia, even in asia :( i make my first reso and do some modification. just like you, but i make more room on body, and put an aluminum plate on top. check my "chayenne" an alden modification, the acoustic sound really loud :) ![]() also check my "iVee telecans" project, an aluminum and brass body. |
