Is that 10 cent RS capacitor good enough?
Institute of Incomplete Guitar Projects |
![]() Poster Extraordinaire
and yet again .... all that matters for caps in passive guitar circuits is value, tolerance and build. anything else just doesn't matter and can border on snake oil hype.
![]() fretted instrument tech ~ custom partscasters Cavalier Single Coil Pickups Molon Labe - come and get them! |
www.parasound.com/pdfs/JCinterview.pdf
Start reading at page 12, should you wish. Point being, there are many ways to measure and many ways to think.
"Everything is a tone control" -donh- |
#4 (permalink) | |
yes, as long as the value and tolerance are correct. it pays to check cap tolerances, some are waaaay off in value.
I'd say yes to the initial question, too. Having designed analog and digital PCBs in the past, all what matters in regards to capacitors in a guitar is the capacitors value and tolerance. Since the capacitor is hooked up to a potentiometer and lengthy guitar cable, what you hear in the end, after squeezing everything through a cranked up amp end effects pedal collection will be mainly be influenced by the position and value of the pot and a bit influenced by the cable.
The material out of which the capacitor is made, is less relevant for guitars. In regards to a guitar's sound the capacitors dielectric (isolating material) is probably more marketing and revenue in my eyes. A capacitors dielectric material come to play when you operate with highly sensitive "sample & hold" circuits (needed when digitizing analog signals, before the A/D converter) where teflon and polypropylene are considered an excellent material or when you design / operate with high frequency like MHz or GHz. Not going into too many technical terms. You can look at it like this: Each capacitor has a minimal resistance value –R- and a minimal inductive value –L- besides the intended capacitive value –C-. The L and R values is depending on the construction and material of the Cap. For the purpose of a capacitor in a guitar (dimming the high frequencies) and the overall frequency range of a guitar all what matters is the C value, because your pickups will likey outgun any of the capacitors resistive and inductive effects, by the nature of the pickup’s L and R values. Of course if you want to build an exact vintage replica of an instrument and or if you like details and an authentic touch then I’d put the same capacitor type in as well. It is all personal taste, like picking abalone shell over white shell for the inlays Last edited by I_build_my_own; December 1st, 2012 at 12:07 PM. |
I agree.Some of the best sounding caps I've ever had were the little RS "Chicklets".
"For You,Lord,are good,and ready to forgive,and abundant in mercy to all those who call upon You." Ps. 86:5 http://www.soundclick.com/bands/0/refin_music.htm MASTER VOLUME? WHAT'S A MASTER VOLUME? |
Probably so. I'm skeptical when I hear all the mumbo jumbo hype about $100 vintage bumblebees and such, try some different ones if you must, but I don't think I could hear a difference.
But heck, I have almost never actually used a tone control, there's usually one on your amp that's more effective. I always have the guitar tone knob wide open, so I'm probably the wrong guy to ask. Last edited by Fred_Garvin; December 1st, 2012 at 09:11 PM. |
I don't have "tone" pots if I'm the one doing the wiring. Best cap is one you leave on the bench!
You need to roll the dice to be in the game. |
#13 (permalink) | ||
Last guitar I built has no tone circuit in it either.
#14 (permalink) |
Sometimes I think we get caught up in the numbers. 10 cents or 10 bucks, hand rolled paper and oil or polystyrene, bottom line is that it either sounds good or it doesn't. If it sounds good to you, then it's good enough.
Ya - that's it - IMO. There is a lot to the properties of dielectrics - resistivity permittivity.... that address the differences in how lossy each type is - I would not say that it does not matter: Just that for a tone circuit in a guitar it does not matter all that much. For almost all audio path applications, I use the green mylar caps for things in the uF range - and ceramic for the pF range - there's diminishing returns to put any more thought into it. There's really no substance to tone circuit cap differences - but the type of cap can make a difference and that is why there are different kinds of caps.
I've built a lot of stomp boxes where the type of caps made a noticeable difference in the feedback to or pre-emphasis circuit on an opamp - or even the voltage ratting - since in that application _any_ combing or asymmetric loss in the filtering causes a circuit to loose limits and then cool stuff happens... If the type of cap is going to make a difference then it matters - and in some circuits it does - but not for a simple low pass tone control in a guitar. The value of the resister and cap are pretty much all you need to figure in - the tolerance of the parts is not all that important. |
#16 (permalink) |
Skip to 5:30 to see him compare a bunch of caps.
He plays a bunch of different ones, i thought it was interesting.
-BB I like guitars. You can make anything you want, and make it the way you want. That's what I love. |
#17 (permalink) |
actually, in a passive guitar, you don't hear the cap, what you do is NOT hear the cap…. what you do hear are the remaining frequencies that the cap has no influence over…
Think of a small library, with 5 books in it, you decide you are going to read four of them and ignore one specific book, so someone removes that book, does the absence of that one book, in any way impact the contents of the other four? Nope… not in the least. That's what the cap does, it removes a specific range of frequencies, having no impact on what remains. The remaining signal is simply devoid of whatever frequencies the cap allowed to escape. Ron Kirn
“Silence in the face of evil is itself evil: God will not hold us innocent. Not to speak is to speak. Not to act is to act.” — Bonhoeffer www.ronkirn.com |
#18 (permalink) |
Anyone remember that Far Side cartoon "Raymond's Last Day As The Band's Sound Technician" where he's reaching for the "suck" knob on the console? That's what tone controls are, IMHO. I've never played a guitar and thought, "It's just not muddy and bland enough"
#19 (permalink) | |
Or bringing a rhythm part into the "background" so to speak. |
#20 (permalink) | |
