1st tele build - pennycaster partscaster- on the cheap all input welcome!
hey guys,
this is my first build and would welcome any and all input! It's called the penny caster project: a build on the cheap! I made the body from Mahogany Scraps from the last deck job I did. It's a six piece lam 3 across, 2 deep and measures 1-7/8" thick. I roughed the shape tracing my squier 51 and "eyeballed" the top bout. Rough cut with a bosch jig saw and sanded with a Ryobi spindle sander. I had the winning bid of $21 for a "vintage series" SX rosewood tele neck with nut, tuners, string trees and pups. I couldn't pass up that one! Here's what I have so far... ![]() Again, budget is a major factor so here are my choices for the bridge assembly: http://www.ebay.com/itm/380502101698...84.m1438.l2649 Control plate: http://www.ebay.com/itm/280794778930...84.m1438.l2649 My plan is to go sans pickguard. I know my glue up could have been much better interms of matching grain/color. 20/20!! I was going to use a 4' drywall sq. to get my bridge, pups and neck pocket all in line with eachother. I have to do a site search on measurments as to where the bridge, pups should be placed and for the length/depth of the neck pocket. I know I still need strap buttons and jack/plate and find out if I should shield the cavities. I'm off and running and will post as I progress! Thanks for reading and any input you may have! KC
"How much more black can it be? Non-more." Last edited by KCKC; November 29th, 2012 at 08:13 PM. |
looks good so far. I like cheap
"The difference is that you're crazy like Nicolai Tesla and I'm more like the guy who sniffs paint and rides his bike down the middle of the road" - Me to Crazydave911 |
Heres a loaded control plate that eats that one on ebay for a few extra bucks full size pots and Sprague Orange capacitor 0.022uF
http://www.eyguitarmusic.com/New-Qua...uF_p_1043.html Great site I buy most of my parts from them if you don't mind waiting about 3 weeks to get them thats the only draw back. Looking good though
But this goes one louder. My Tunes can be heard here: http://www.facebook.com/pages/Phoeni...p_178091127385 |
Awesome mate let me know what it's like.
Don't cheap out on pots. Even the best are pretty inexpensive. Full size like CTS or alpha are the best imo, the minis come on cheap import guitars.
250k if you want to use single coils. 500k if you want to use humbuckers. 500k will sound brighter than 250k, usually too bright for an already bright tele pickup. |
To follow-up on my pots question
Is there a big difference between the brass barrel saddles and the brass compensated saddles that are found on bridges like wilkinson? It's my understanding that the compensated saddles intonate better. kc
"How much more black can it be? Non-more." |
I hope it turns out great...
my "raftercaster".... cheap as chips.... the neck cost more that the rest.... (MM).. and it's got... A MINI POT !.. up front... I put the Volume hole too far forward by 1/4 inch and a full size pot hits the front of the rout... grrr... I'm going to make another plate....a longboard... and re-arrange the controls... cowabunga dudes...
"by degrees the flood of music drove all speculations out of his mind. It was as though it were a kind of liquid stuff that poured all over him and got mixed up with the sunlight that filtered through the leaves." |
That looks great trev333! What type of finish did you use on the body?
For cabinets that I build I've been wiping on regular poly in super thin coats and using 0000 bronze wool to between each then finish with a light 0000 bronze wool and rub on a light coat of lemon oil and it comes out slick - no pun intended! Might give the tung oil a shot this project though. kc
I just used Danish oil ... it's starting to mark up a bit from picking.. the Oregon is a bit soft.... and a spray enamel cream top...
maybe surfboard resin on top?.... that should toughen it up...;) this one was my first body build, too... it's like a self imposed rite of passage around here...:)
#16 (permalink) | |
if it's not BROKE, MOD it !!! Weapons of Self Destruction... http://fandalism.com/bigwhisky |
#18 (permalink) |
the size of taper is the difference, you will get more high end out of a higher value and a mellow end out of the lower but, anything lower than 100K or higher than 1M is useless in my experience... I some times mix the two and use a 500K volume if my pick ups don`t have enough spank... as for the size, that`s debatable I find no difference... hope this helps
#19 (permalink) | |
#20 (permalink) |
OGC4, It's the standard up here in MA. Standard deck project is all PT framing, Mahogany or Ipe decking and stainless fasteners if going the real wood route. The composite and plastic decking is becoming very popular in New England.
Again, there are a wide variety of Mahoganies and it's my understanding that what's imported for decking is farmed. Some of the wood afficianados like Colt might chime in here with better intell. kc
