Some Cocobolo, Maple, and Black Limba ... Lap Steels Rule!
Here is a fun one I just finished up and thought I'd share, FireDog 001.
Some basic specs 24" scale Body is chambered black limba with a curly maple top fretboard is cocobolo rosewood with mother of pearl fret and position markers pickups are some custom BG-Pups 8 string HotRods with rosewood trim 4 way rotary switching matching rosewood knobs String through rosewood set bridge with bronze saddle Hipshot locking tuners Tru Oil finish, maple coloring achieved with a wash coat of amber shellac flake . ![]() ![]() ![]() ![]() ![]()
Some misc pics of lap steels I've built |
He's built a few more of these. I consider you both to be masters. That tru oil finish is to die for. Just a seriously beautiful instrument!!
Please like my Facebook page at...http://www.facebook.com/DeltaGuitarWorks Visit my music and songwriting page at...https://www.facebook.com/TheWildwoodSessions |
Thanks all! ... I am very happy how she turned out ... easy on the eyes with a great voice too
Thanks! ... I've been doing that round raised style for a while now and like it a lot. I'm in the process of designing an etched nickle silver version that should be cool too .. will see soon enough. Nothing wrong with your steel, I liked it a lot! Fancy wood does not make them sound or play any better. Not as a rule. The angle your seeing is because I took the pics before I fully filed the slots in the nut. At this point all it had was the shallow starter cuts from the razor saw. Tru Oil can really bring out the beauty in wood, but to be very honest, its a pain in the butt when going for that flat mirror gloss finish. Its not so hard as it is just plain time consuming. Its about a 2 week process and by the time I'm done, the whole guitar has been fully wet sanded 5 - 6 times before the last coat goes on. Its basically an exercise of building it up and blocking it down till all is level and flat. I've thought the same as well ... one of these days I'll have to give it a go.
#10 (permalink) | |
I've only done necks with Tru Oil. What's your procedure for wet sanding (grits, etc??). Do you find that you sometimes sand through one layer into the next?? Do you get witness lines?
I wet sanded my last neck and got a very smooth gloss finish, but I couldn't tell if I had sanded through one layer into the next. Quote:
#12 (permalink) | |
the now mandatory =====> |
#13 (permalink) | ||
Thanks again all!
Working within those realities, my whole thought process / approach is to level as I go ... build it up and block it down. During the film building phase I'll wipe on 2 - 3 coats a day, let cure overnight, then wet sand the next morning before that days coats. For me, I've found that wet sanding with 1000 grit and a drop or two of mineral spirits works well. The 1000 grit seems to be a good balance as it cuts fast enough for results without being overly aggressive on the fresh and fragile new finish. Once I hit the point where everything is flat and level, I'll spray the last couple of coats and use 1500 grit between those. Once the last coat is sprayed, I let it cure / harden up for for 5 - 7 days and polish as needed. If you did a good job building up and leveling as you go, often just a light polishing is all thats needed in the end. Quote:
I do plan on developing a more beginner / intermediate focused steel and will need to standardize on an alternative product for that price point. For the higher end stuff I'll continue to keep Tru Oil as an option.
#15 (permalink) | |
The down side is that it is expensive. Over 100$ a gallon, and doesn't store very well.
