More Router Bits
I'll lead off by apologizing for being dense, but I've read through some old threads on router bits, but I'm still a bit confused...
So here is my request, if some of you experts would be kind enough to chime in: Can you please post your essential router bits, with links directly to the exact bits you prefer? If it's only possible to link to a list with a bunch of bits on the page, please spell it out for me like you would a kid! Thanks so much! |
I think you could get by building a Tele with just a 1/2"x1" top bearing flush trim bit. Make sure it has carbide cutters. http://www.homedepot.com/Tools-Hardw...&storeId=10051
It will take several passes to pattern rout the body with this bit, but that's OK. If all your templates are 3/4" MDF, you can use this bit to rout the PU's, neck pocket & control hole also. You could also use a 1/2"x1/2" top bearing flush trim bit for those routs. If you want a round over, it just depends on the radius you want. 1/8", 1/4", etc. If you have lots of money and a 1/2" collet router, it seems the most popular bit for routing the body is a 2" spiral upcut bit. http://www.amazon.com/RFT5200-CARBIDE-UP-CUT-SPIRAL-ROUTER/dp/B0012JI870/ref=sr_1_13?ie=UTF8&qid=1342882174&sr=8-13&keywords=spiral+upcut+router+bit With all router operations, be very careful. Have respect for the tool. Let it do the work. Don't force it, take as little wood at a time as possible. Wear eye & ear protection. Have fun!
Telecaster - The AK-47 of the guitar world. Some may think its ugly...but it works! |
Im no pro and have only started my first build which is currently beyond all the wood working stages...........I had to have a top bearing flush cut bit that is 1/2" wide and 1" long for neck pocket, pick up, and control cavity routes. . I also used a 3/16 round over bit to round the edge of the body but most guys use a 1/8 round over. A channel bit is needed to route the groove for your truss rod according to the width of the truss rod. I wouldn't think you would require additional bits unless you ventured into veneers or pick guard making. Like I said, Im just learning myself, but needed these 3 bits to complete my build...........good luck with your build!
Jeff
" As long as they keep making guitar strings and gun powder Im good to go . " |
Good point about the truss rod slot - I forgot that one. A 1/4" spiral bit works pretty well.
Tele:
1/2" Pattern Routing bit for pickup,trem, control, and neck routs- Stew Mac pattern bit... 1/2" D by 1" long Flush Trim bit. Freud from Amazon.com 3/16 Radius round over bit for edge radius...Freud... Amazon.com 3/16" straight... truss rods. I use the stewmac hot rod bit. Strat : 1/2" Radius for edges- Lowes or other home center. Set neck cavity and also control rout on tele or strat- 1/2 "D x 1" pattern bit- Freud...Amazon.com Humbucker rout- 1/4" straight bit. Usually available where router bits are sold. You get what you pay for with router bits. Freud, CMT, and Whiteside last 2-3x as long as your cheapie ones and sometimes are only a few dollars more than home center prices online. If you get a router, get one with a 1/2" collet.
Institute of Incomplete Guitar Projects |
I posted links to about every tool, bit, and template I use, on this thread...
http://www.tdpri.com/forum/tele-home...ar-custom.html http://www.tdpri.com/forum/tele-home...ar-custom.html |
#10 (permalink) | |
How do you like your drill press? I'm very close to getting that one as well... |
